L2501 will not start
DWTrisler
L2501
Oct 18, 2022
11
Tennessee
L2501 will not start. was working and then just quit. Question: how do you jump(bypass) the PTO safety switches to isolate them from the system during troubleshooting?
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
I'm not sure why you think it's the PTO safety switch. I've had far more trouble with the seat safety switch than anything else. It turned out the rod which enables it to raise had become detached at one end.
Mark_BX25D
Bx25D
Jul 19, 2020
1,756
1,278
Depends on your tractor. Some safety switches just open the circuit. In that case, you just add jumper around them. Easy with a short section of wire and an alligator clip on each end.
Some close the circuit. In that case, just disconnect them.
Use a meter to see which way yours work.
BigG
Sep 14, 2018
1,951
770
West Central,FL
The PTO lever on the transmission is controlled by the lever upon the fender. It is very often the cable that connects the two becomes stuck. The top lever will move to the off position but with the bound cable the bottom lever does not move. Spray the cable with something like PB Blaster and see if it will move the lower lever and allow the the tractor to start.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,360
1,794
Western MT
Also, take a look at this thread if your tractor is a HST. The steps I took to fix are in the last post.
DWTrisler
L2501
Oct 18, 2022
11
Tennessee
Thanks for all the inputs. Dealer service says its a bad safety switch. Mine is gear driven not an HST. I read the PTO switches with my meter and the are closed. Per the schematic, the switches close to allow voltage to the system when the PTO in disengaged. The seat switch is not in the starting sequence. Battery is good and charged. Starter has been bench tested. I think I am down to the ignition switch. Because the stop solenoid sometimes clicks when the ignition switch is turned and sometimes not. Thoughts?
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
I have a gear drive L, when this happens on mine it’s the range switch. Usually gets grass/debris in it.
edit to be more specific…it gets debris in the range shift lever and doesn’t let it return all the way to activate the switch.
DWTrisler
L2501
Oct 18, 2022
11
Tennessee
I checked that too. I put a jumper wire on it just to double check. No joy.
Mark_BX25D
Bx25D
Jul 19, 2020
1,756
1,278
Get your meter out. Disconnect the switch (label the wires and terminals). Test the switch 10 or 12 times. If it fails even once, replace it.
mdhughes
L3901DT
Dec 10, 2014
1,252
722
Ste Geneveive county, MO
Have you check the Range Gear Shift Lever safety switch?
From the WSM:" When the PTO lever is set to "Disengaged" position and the range gear shift lever is set to "Neutral" position,the engine can be started "
