L2501 ROP height ?
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Can anyone who owns a L2501 or another know same frame sized tractor tell me the distance from the ground to the top of the ROP and please mention what style of tires you have like R1, R4, or if you have a canopy.
Thanks
Shadetree03
L2501, King Kutter, Landscape Rake, Titan 3pt forks
Sep 20, 2017
115
12
Pueblo, CO
Just pulled back in with a landscape rake on the back.... 90 1/4 inches with R4 tires at 30 psi on the back.. No Canopy.
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Wow almost 8 foot.
I know it can be folded down but Im not sure how easy it is.
Now I will go measure my shed entrance height tomorrow morning.
Thanks for the info.
Shadetree03
Sep 20, 2017
115
12
Pueblo, CO
Yep, I got lucky as it just clears the entrance beam on the carport. Easy to spin the two bolts out after pulling the hairpins, and that gets you about 20 inches of clearance,,, enough to get pulled in further under my ceiling racks:)
Trav7
Barrington il usa
Wow almost 8 foot.
It’s a bolt on each side so it’s not too bad.
I opted to put my bolts in the down position and bought two hitch pins (grade 5 1/2”. ) to use as a quick release since I have to drop the rops for my garage and shed any time I use the tractor
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Thanks for all the help and advice.
I just got back from the shed and with a varying dirt floor Im right at 8'-2" to 8'-4" so I should be good to go, thank goodness.
Thanks again
Poohbear
Jul 6, 2018
472
133
Gilmer,Tx,United States
I forgot what I measured when buying but my L3301 with R4 tires clears my 7ft 10 1/2 in. opening with room to spare.
