Wow almost 8 foot.Just pulled back in with a landscape rake on the back.... 90 1/4 inches with R4 tires at 30 psi on the back.. No Canopy.
It’s a bolt on each side so it’s not too bad.Wow almost 8 foot.
I know it can be folded down but Im not sure how easy it is.
Now I will go measure my shed entrance height tomorrow morning.
Thanks for the info.
Yep, I got lucky as it just clears the entrance beam on the carport. Easy to spin the two bolts out after pulling the hairpins, and that gets you about 20 inches of clearance,,, enough to get pulled in further under my ceiling racks
Thanks for all the help and advice.It’s a bolt on each side so it’s not too bad.
I opted to put my bolts in the down position and bought two hitch pins (grade 5 1/2”. ) to use as a quick release since I have to drop the rops for my garage and shed any time I use the tractor
Excellent.I forgot what I measured when buying but my L3301 with R4 tires clears my 7ft 10 1/2 in. opening with room to spare.
