Yes. Do you have a loader on the tractor?Does anyone make a hydraulic block for rear hydraulics
Yes I have a loader on the frontYes. Do you have a loader on the tractor?
Then you font need a block. Feed the remotes from the loader.Yes I have a loader on the front
That is assuming that the loader is already powered by the tractor hydraulics or that you will use the same separate hydraulic pump as the FEL is using. But regardless of that it is easiest to pipe into the FEL valve for the rear remote valve.Then you font need a block. Feed the remotes from the loader.
See this thread for a discussion of the adapter block that might fit your tractor. It matched my L185.Does anyone make a hydraulic block for rear hydraulics
