L245dt rear hydraulics
3,164
Then you font need a block. Feed the remotes from the loader.
That is assuming that the loader is already powered by the tractor hydraulics or that you will use the same separate hydraulic pump as the FEL is using. But regardless of that it is easiest to pipe into the FEL valve for the rear remote valve.
3,164
Does anyone make a hydraulic block for rear hydraulics
See this thread for a discussion of the adapter block that might fit your tractor. It matched my L185.
post #1 shows the dimensions
