L245dt rear hydraulics
3,165
Then you font need a block. Feed the remotes from the loader.
That is assuming that the loader is already powered by the tractor hydraulics or that you will use the same separate hydraulic pump as the FEL is using. But regardless of that it is easiest to pipe into the FEL valve for the rear remote valve.
3,165
Does anyone make a hydraulic block for rear hydraulics
See this thread for a discussion of the adapter block that might fit your tractor. It matched my L185.
post #1 shows the dimensions
7,377
No - it neans he can run the remotes off t
Any chance you could tell me how or show pic thanks
Show me a picture of your loader valve.
3,165
No - it means he can run the remotes off t(he loader valve).
That is exactly what I said. I was just pointing out the two places where the flow could be originating from (and that it really doesn’t matter where the source is).
