Thinking about your question it can be done either way if I understand your question right. I think its set to measure absolute zero like a bubble level would. I assume it uses mercury bubbles/switches inside.This interests me, but raises a question:
Does this measure absolute level of inclination, or does is somehow measure the angle of inclination relative to the tractor? In other words, if you're grading directly down and trying to maintain a 10 degree slope with the tractor, will a 0 degree (bucket edge "even" with the imaginary line drawn through the contact patch of the front and rear tires) reading on the inclinometer match the 10 degree slope that the tractor is on?
The current angle iron level on the tractor that kubota puts on- that shows the level of the bucket relative to the ground I guess? If your tractor is on a slope then the angle iron would also be sloped down with you - so to use the angle iron - you would move it level to be level with the ground and not the tractor? Both my properties are mostly flat so I never thought of that problem/feature
When I say the inclinometer I have can be used both ways - it's because you can reset the absolute 0 on it. So I would normally have it set for zero to be set to absolute level (that any bubble level would achieve). But if I had a project on a slope that I wanted to be graded with the slope I could set the 10% incline lets say to be 0. Now if the incline isn't consistent then not sure its gonna work out. *shrug*
First rule of fight club is we don't talk about how much our toys/hobbies cost us. Lest we invite wife rage!Another tweaker in the group....
I wouldnt want to guess at the dollar figure.
I know exactly how much everything is so far - but she only knows a soft number I probably spend too much time tweaking things. Could probably just leave things alone, but that ain't me.....
