Kubota B2650 Key Stop fuse repeatedly blowing
Medic1690
B2650
Oct 18, 2021
82 hours on B2650 with loader. Started blowing key stop fuse randomly without any pattern. Sometimes runs 30 minutes, sometimes 5 minutes before it blows. Have tried to trace wires to no avail. any help would be greatly appreciated
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
I believe that model has an issue with the hst pedal switch shorting out and blowing the fuse. Ill see if I can find the thread(s)
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
A couple threads, a shorted pto switch was also mentioned.
Medic1690
B2650
Oct 18, 2021
thank you sir, i have read so much on "shorts", "grounds" etc i am overwhelmed a bit. I am a medic for goodness sake....body mechanic not tractor one. i did break down and buy a WSM
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Attached a link to a thread I replied in regarding the trundle switch replacement.
I haven't had issues with fuse's yet....but that switch was sure annoying.
Go buy one and have it ready for when it fails. I picked up a spare!
Kinda like having a 7.5mm ready when you think you can get a 8.0 tube as back up!
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
If its not related to the hst, it may just be the stop solenoid. The windings go bad and they get hot absorbing too much current.
It is located by the injection pump.
sardillim
b2650
Nov 24, 2019
126
62
Easton
I had a similar problem with my B2650. check the ignition switch if it's loose the switch could rotate and short out against anything metal behind the plastic cover. it's just a matter of repositioning the switch and tightening it if that's the problem good luck
Medic1690
B2650
Oct 18, 2021
Now that’s language I can understand!!!!!
