82 hours on B2650 with loader. Started blowing key stop fuse randomly without any pattern. Sometimes runs 30 minutes, sometimes 5 minutes before it blows. Have tried to trace wires to no avail. any help would be greatly appreciated
I believe that model has an issue with the hst pedal switch shorting out and blowing the fuse. Ill see if I can find the thread(s)82 hours on B2650 with loader. Started blowing key stop fuse randomly without any pattern. Sometimes runs 30 minutes, sometimes 5 minutes before it blows. Have tried to trace wires to no avail. any help would be greatly appreciated
Nice Bike, it is covered but dealer is couple hours away....and of no helpAt 82 hours the unit should still be under warranty.
thank you sir, i have read so much on "shorts", "grounds" etc i am overwhelmed a bit. I am a medic for goodness sake....body mechanic not tractor one. i did break down and buy a WSMkubota b2650 wont start
hi guys can you help my b2650 kubota tractor will not start when I turn the key it keeps blowing the 5amp fuse which is listed panel/opc I have tried bypassing the seat tractor turned over but blew the fuse again also was told to replace stop solenoid which I have done but no joy. thanks bryanwww.orangetractortalks.com
A couple threads, a shorted pto switch was also mentioned.
Now that’s language I can understand!!!!!B2650 HST Pedal Switch
My tractor died on me, just like I'd turned the key off. Wouldn't do anything when I turned the key to the start position. After checking all the usual culprits I noticed the dash was not lighting up. Started checking fuses and the Panel OPC fuse was blown (5 amp) Replaced it and tractor...www.orangetractortalks.com
Attached a link to a thread I replied in regarding the trundle switch replacement.
I haven't had issues with fuse's yet....but that switch was sure annoying.
Go buy one and have it ready for when it fails. I picked up a spare!
Kinda like having a 7.5mm ready when you think you can get a 8.0 tube as back up!
