Hey guys, Im new to the forum and looking for some thoughts and advice. My B1550 doesnt have any visible hydraulic leaks, my hydraulic fluid after a few hours needs to be topped off, and my engine crank case keeps filling past the full line on my dipstick. I'm making an eduacated guess that my issue is a seal on the engine driven hydrualic pump. I did see another forum on here that someone was having the same issue on a b1550 hst and the seal and o-rings fixed the issue.
My question is what seal(s) am I replacing would it be p/n 31381-76190( Ref 80). Or is it other o-rings too? I will order the hydrualic pump to gear pump holder gasket (ref 20). Do I need to order the gasket from gear pump holder to crank case or no becuase that will not need to be removed? Is there any other things I need to buy? Thanks in advance!
