Kubota B1550D hydraulic fluid in engine crankcase.
Porcello garage
Kubota B1550D
Jul 4, 2026
32
Enfield ct
Hey guys, Im new to the forum and looking for some thoughts and advice. My B1550 doesnt have any visible hydraulic leaks, my hydraulic fluid after a few hours needs to be topped off, and my engine crank case keeps filling past the full line on my dipstick. I'm making an eduacated guess that my issue is a seal on the engine driven hydrualic pump. I did see another forum on here that someone was having the same issue on a b1550 hst and the seal and o-rings fixed the issue.
My question is what seal(s) am I replacing would it be p/n 31381-76190( Ref 80). Or is it other o-rings too? I will order the hydrualic pump to gear pump holder gasket (ref 20). Do I need to order the gasket from gear pump holder to crank case or no becuase that will not need to be removed? Is there any other things I need to buy? Thanks in advance!
7,310
View attachment 176619 View attachment 176622
Shaft seal #80. It can be replaced without taking the pump apart.
3,115
There are also some o-rings at the points where the pipes enter and exit the pump. They are probably fine to reuse but I personally replace them anytime I break an older connection just for peace of mind.
added on edit
Those joints look like banjo bolts so instead of o-rings there will be two crush washers per bolt (4 total).
3,115
Crush washers are the #110 and #120
Porcello garage
Kubota B1550D
Jul 4, 2026
32
Enfield ct
You have to remove/disconnect both top and bottom pipes. Replace all the crush washers - 110, 120 and the ones on top.
Im not sure what you mean sorry, so I need to removed the hyd selector and the pump so should i order qty 1 of 110 and 120 and then order 130 o-ring for bottom pope? Do I need the 020 o rings?
7,310
The hydraulic pipes and the outlet block are attached (sandwiched) to the pump with two banjo bolts. You should replace all of the washers and o-rings between those components. You can get away with reusing the rubber seals but not the copper washers
No code has to be inserted here.
Porcello garage
Kubota B1550D
Jul 4, 2026
32
Enfield ct
Thank you so much guys, where do you guys recommend I buy or download the service manual. Does kubota have a shop manual with removal and install instructions with proper torques? Or am I just a spoiled avaition mechanic with manuals like that lol. I have never removed anything on my b1550 so I want to make sure I do it right.
7,310
Free download:
You probably wont find tightening torques but this is not an aircraft.
Porcello garage
Kubota B1550D
Jul 4, 2026
32
Enfield ct
Hey all, So I finally got all the parts, and I got the pump removed. Is this damage or machined on the pump shaft and the bearing on the engine side?
I also don't see any visuable damage to the shaft seal. But going to replace it anyways whats the best shop practice to pull the seal screw in a few screws and pull on it?
Thanks in advance!
@TheOldHokie
@Russell King
IMG_0797.jpeg earing on the engine side?
7,310
Thanks in advance!
@TheOldHokie
@Russell King
View attachment 177558 earing on the engine side?
Thats damage to both the tang on the pump and the drive slot.
