Introduction and questions..
A.O.
L3540HST LA724 FEL
Feb 6, 2015
120
South Carolina
Hi, Just bought a 3540HST with a LA724loader with a 4 in 1 bucket.. I'll get back to the bucket in a minute.
Not new to tractors, just new here. This is my third Kubota, M5400, L3010, and now this one.. couple fords and a David Bradley before that..
First question on a rotary cutter (brush hog or whatever) . Kubota says this tractor will take a 6 footer, seems to be getting mighty long at that size and a lot of my working will be in the pine woods of South Carolina.. Thinking a 5 footer, whatcha think? Ok or too small?
Back to the 4 in 1 bucket, all my Kubotas and the David Bradley have had loaders and I can work them pretty well for grading,spreading and things like that. BUT.. I seem to be a complete idiot concerning the 4 in 1.. is there a tutorial on how to use one? And I don't mean the controls, but how to actually use one on the ground . I've seen a couple little u-tube videos on people using one, but I'm looking for more of a teaching arrangement.Is there one out there? I've looked and have not seen any..
Thanks, Scott
2,230
Thanks, Scott
Cant help you with the edjamacation on the bucket.....never had one that fancy !:)
As for the brush hog, if your tractor is lets say....4' 8" wide, just guessing, then I would get a 5' er, but if your tractor is wider than 5' - 0" - if it will handle the 6' - get it!!!!! Never go to small on the hog. YOU always want the cutter to be WIDER than the tire settings. You run next to a fence line and you want to cut the grass and not get hung in the fence.
A 6'er will be a hellva lot more $$$$ than a 5' er. I have never seen a used 6' under $600, most hit the 1k mark if they are any good. A 5' er will be $$ cheaper. However - time = money, if you are trying to cut in a "fast" time then the 6' will reduce time by about 20% or so...while using about the same fuel/hour. It is one of those pay me now or latter type deals, pay more for the 6' and cut quicker, or less for the 5' and cut longer.
Looking at your tractor - it says that a 72" MMM works on it ......I would get a 6' brush hog and never look back! :D
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Welcome forum from Alabama. I agree with Hokie. I have a 55.1" wide L3200 and I got the 5' (60") cutter.
The_Al
L3540, Heavy duty FEL, 9' bachoe, Brush hog, 72" grappler
Jul 19, 2013
154
MA
Thanks, Scott
I have a 6' on my l3540. I have a grappler on here that I swap out vs. a 4 and 1. HTH
Gundoctor
Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
I have a Grand L3540 also. I have a Land Pride 72" finish mower. It is to much for this tractor. The engine is 35HP but the PTO put out just 28.5 HP. I now wish I had a 3940. I can mow faster with my Z-Turn than this tractor.
Tooljunkie
May 13, 2014
4,150
4 in one bucket is sweet. That is usually put on crawlers. Need to hunt up all the videos you can get your eyes on, so versatile and so many uses.
A.O.
L3540HST LA724 FEL
Feb 6, 2015
120
South Carolina
Thanks guys... Yeah, I have right at 70 inches to the outsides of my tires..6 foot it is I guess.
2,230
I think you will be frustrated with a 5' er.........
Get the 6' and find a good deal - and hopefully the grass will not be tooooo tall!:)
