How do you deal with snow?
Stmar
B2650HSDC
May 23, 2017
949
58
Buffalo, Wyoming
I agree... just skim.. but I had a neighbors gravel driveway I did to help. I found a bit pf prep prior to frozen ground and yes... snow. I would go across the fields with my front blade and grade the driveway smooth. Man... that really helped when the snow did come... enough so that I would grade between snows.... made my life so much easier...
I keep my drive graded so no ruts and minimal humps. After I grade I use a drag to smooth it out, an old harrow with the spikes removed with an old cutting blade attached for weight and surface drag.
TRA
B2601, LA434, BH70, LP BB1260
Dec 17, 2017
88
Rock Hill
Right now, I just have a box scraper. But im thinking of a front plow, once I put in the gravel road.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
696
202
Rising Sun, MD
Front plows have down pressure...I use that to take off the heavy stuff and float the blade letting two round 8"x 1" armor plate skids ride on the gravel. If the gravel is frozen... it works pretty good. Since I have had the front blade... the drag blade on the back is only for counter weight
BX25DMan
Kubota BX25D
Sep 16, 2013
111
Southeast MA
Hello everyone,
I am new to this site and new to Kubota. We have had JD4110 for the last ten years for snow removal and driveway maintenance. We got our new B2650 HDSC a few weeks ago and waiting for snow. Thanks for all of the great information.
Son, you've hit the mother-load!!
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,336
858
under a rock
First year with the BX
It sure helped with the hard-to-reach places
I can’t get to with my snowplow.
Next year I will definitely take the mower deck off in the fall.
Did a great job though
We got about 13 inches last night.
Colder than a witches broomstick too
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
Being a retired equipment operator, I am just used to running loaders, so I just use my front loader. That way I can push it and wing it off the drive on the down wind side, without leaving big windrows on the edge of the drive to drift back in at that height. Can pile up the snow if we get alot here in the snowbelt, and can rescue the neighbors and push there snow back when they run out or room.
Butch
Sep 10, 2009
696
202
Rising Sun, MD
Damn.... I wondered why they put seat belts on botas....
Butch
Sep 10, 2009
696
202
Rising Sun, MD
I have a "Copper Snowman" with a long copper nose.... at the end of the nose is connected a 1/2" copper tube slinky.... he is my friend.... he has been known to spit out brandy, rye "stuff".... ect
Not a large snowman... I'd say he is pretty close to a 10 gallon vessel.
Seat belts definitely required... even in a recliner...
nbryan
Jan 3, 2019
1,430
948
Hadashville, Manitoba, Canada
B2650 ROPS with B2782B 63" front blower w/hydraulic chute, and Land Pride BB1560 box blade.
Friggin' awesome.
Watch for certain sized gravel stones in driveway, I'm going through auger shear bolts steady, until first passes firm up and smoothes the pit run gravel. Next year I'm putting crushed gravel topping on top of driveway and parking area, in time for it to be nice and compact/solid for next winter.
Find a squirt can with a nozzle that can handle winter grade chain bar oil in the cold. Re-lube the chain drive every 4 hours max.
The zerk for the u-joint attached to the blower at the pto input shaft is difficult to get to. Rotate shaft until zerk faces down and raise shaft - you should be able to feel the zerk behind the pto safety shield and fit the gun nozzle. Can't see the zerk, but it works.
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
238
88
S.E. TN
After dealing with snow for 58 years, I retired and moved to southern Tennessee. If it snows here, it’s melted in a few hours:)
5,631
Dad had the best idea he said God put it there and he can take it away! Butch, I think I may have met a cousin of your snowman, but he had a bad case of reflux ;)
