Fords are junk
5,188
" A Boeing 747-400 will weigh 403,500 pounds (183,024 kg) when empty. "
@lugbolt was pretty darn close with his numbers.
Lugbolt did not reference either empty or MGTOW 747-400.
Empty = your 403,500 lbs. v/s full = 870,000 lbs.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
😳 does this count for the beverages?
11,757
My uncle owns a 2001 f250 crew cab short bed. With a winch bumper and a 90 gallon fuel transfer tank in the bed, it still doesn't weigh 8klbs. I use it quite often to tow since it has a higher gcwr then my 96 f250, Which is a super cab long bed which scales 6400lbs. My dad's 2002 f350 crew cab with the job body fully loaded with a Lincoln ranger 250 welder in the back weighed 9200lbs.
So no I don't believe his truck weight 8klbs unless he's hauling an extra 2k lbs of weight around.
My F250 7.3L Lariat Crew Cab with 6-1/2' bed weighs 8,370lb with a full tank of fuel, and two spare wheels in the bed. I have a Snug Top, Decked pull out draw system and Ranch Hand front and rear bumpers. I put the truck on a scale in Sheridan, WY before pulling the M6060 back home.
This is the truck in question.
58Ford
BX23s, LA340, BT603, RCR1248, PFL1242, STB1072
Jan 1, 2022
248
207
SW Washington
I spent a bit of time on some 747-300s as a trolly dolly. I recall the fuel weight being the same as a 767. Can’t recall if that was fully loaded or not? Do you recall fried? We ran a COMBI for a bit and I recall they had to slow it down a couple times - damn thing was fast but stank of horses. I find myself recalling weird info snippets these days!
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Nice looking truck.. but that Kubota makes it look like a midsize. 😁
5,188
I have no real idea about the fuel weight comparison, but I highly doubt those weights are anywhere close to being similar.
After being retired now for 22+ years I actually remember very little......about anything,..... and I never flew the 767. :ROFLMAO:
7,734
That's OK, Thread started off about Fords and how bad they are, then went to the weight of airplanes. ;)
Dieseldonato
Mar 15, 2022
728
439
Pa
Yeah, stock truck in that era would be around 6-6500 lbs. but I don’t discredit lugbolt in the least for his contributions
Not discounting anything he says, just he got a bunch of extra weight in it.
Dieseldonato
Mar 15, 2022
728
439
Pa
Wasn't dobting the weight, just it's a lot of extra weight, which with now knowing all your add on makes sense.
ccoon520
L2501 w/ FEL
Apr 15, 2019
360
109
IA
So with all the videos being posted of 1/2 tons towing massive loads, this video explains how it is possible and why it is just marketing. As a note most trucks can pull significantly more than they are rated to tow but stopping that load and keeping wheel bearings, axles, difs, etc. from needing replaced every 500 miles from overloading is a different story.
Back to on topic the truck has gone 11 or 12 years before the rust became an issue, and the realistic resolution to the pinched brake line would have been using molded plastic, which if it broke would have drove this to be a topic of how things "aren't built like they used to." Additional paint wouldn't necessarily solve the problem because it is in a location where rocks get thrown around so the paint would chip and paint doesn't always adhere perfectly either. A rubber rock guard would more than likely have deteriorated to nothing within 5 or 6 years and more likely than not caused worse rust by trapping in the salt and water.
You can't predict every issue, however, Fords around that age have worse issues that sent a bunch of engines to the junkyard before even reaching 12 years old with their 6.0L, 6.4L powerstrokes and 5.4 tritons.
