BX24 winter cab build
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
184
185
Demotte, IN
Nice. Do you plan on leaving it on full time or is it “easy” to remove?
Any data on the rear wheel weights?
BXHoosier
BX24
Jan 21, 2018
505
616
Indiana
The cab is fairly simple to remove. The doors and back panel can be removed in less than a minute. The front is a little more involved to remove so I may leave it on year round.
The wheel weights are actually a set I made years ago for one of my old Cub Cadet garden tractors. I bought a couple sets of the factory weights for the Cub, so I painted these orange and put them on the Kubota. They’re 50 lbs each.
leveraddict
Apr 1, 2019
905
594
NEPA
I love the ballast can!
BXHoosier
BX24
Jan 21, 2018
505
616
Indiana
Mounted a fire extinguisher between the door and back window. I added some insulation to keep some heat in and hopefully some noise out.
Reactions: 8 users
BXHoosier
BX24
Jan 21, 2018
505
616
Indiana
The insulation seems to have made life a little more bearable inside the cab. I think the top was reverberating and reflecting sound and the 1-1/2” of foam board has tamed it some. I’ve added some foam rubber in a few other places to seal up air leaks.
I had added magnetic latches to the back panel to hold it in place until the inside latches were secured. They worked fine until the windows and gaskets were added which added enough weight that the magnets weren’t strong enough. I found a rubber Jeep hood style hasp that I added to the top of the back panel.
BX23S-1
557
220
No where Special
Wowww, NICE job BXHoosier !
Every winter, i dream of having a cab on my BX23s. Cold is really starting to get to my old bones out there.
Bugzilla46310
May 22, 2022
184
185
Demotte, IN
Carhart insulated bibs and coat with a leather and sheepskin avaitor cap and you will sweat in sub zero weather. Just need a face shield with a window wiper!
B3 Aviator Hat - Antik
BXHoosier
BX24
Jan 21, 2018
505
616
Indiana
A couple more improvements for the cab. A new seat to replace the horrible, sloped factory seat and some plastic filler panels under the seat to seal off some holes. I also bent the loader joystick a little to the left so I don’t hit the window when dumping the bucket.
I got to try out the cab last weekend for a little bit to clear snowdrifts from in front of the garage doors. It didn’t run long enough to heat up the cab but it was definitely nice being out of the -20F windchill.
BXHoosier
BX24
Jan 21, 2018
505
616
Indiana
I pulled the cab off a few weeks ago and tonight I moved it to the barn for storage until next winter. To get it out of the way, I screwed and lagged some 2x4s to the wall to set the pieces up on and held them there with a ratchet strap.
BXHoosier
BX24
Jan 21, 2018
505
616
Indiana
I finally upgraded the heater today. It is rated at 13,200 BTU so it should heat the cab nicely. The door latch handle needs to be reworked because it hit the heater.
bird dogger
Vendor Member
Feb 24, 2019
1,752
1,727
North Dakota
You'll now need a short sleeved Hawaiin shirt to wear while moving snow!! :ROFLMAO:
BXHoosier
BX24
Jan 21, 2018
505
616
Indiana
It definitely puts out much more heat than my homemade contraption of a heater. I’ll hold off on the Hawaiian shirt shopping until I have done more thorough heater testing. Lol
BXHoosier
BX24
Jan 21, 2018
505
616
Indiana
The new heater works great. It was 15* F and with the fan on low I was moving snow with just a flannel shirt on. No hat or gloves.
