LX 2610 Service
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
Doing my first maintenance oil and tranmision change. Are there 1 or 2 filters?
First Service 189 hours. Can you use an air compressor type pump to take out the oil? What is the lower/smaller opening on the engine (says oil like the higher up one) On the hydro side of things, are the drains different than the ones in the owners service manual (seems so) Are there 2 filters?
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
3 filters for fluid, 1 is engine oil, 1 is HST(Transmission) and the other is Hydraulic. Post a message if the google drive link worked.
RMS
LX2610HSDC, RCR1260, PFL1242, LX2963, RB1684, WC-68 Chipper,Flail Mower
Sep 26, 2021
191
319
Buckfield Maine
I had staples printout the pdf. It was cheaper than what the dealership charges for a hard copy.
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
I just printed it out at work. Then used the 3 hole punch, and borrowed a 3 ring binder.
4,163
The thread title says BX and someone posted a manual for a LX. Now I am totally confused. I hate when threads turn into alphabet soup.
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
I looked at what the op owns and just figured that he/her wanted the WSM for what they own. As he/she is asking about the first service it is highly unlikely it is on a BX2610. Oh, and I just google it and Kubota did not make a BX2610.
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
I'm glad you're not working on anything I own.
Yes, big difference between net netters and real mechanics, just look at u-tube. I want one w/photos which the cheapie print-out which does not have photos from what I hear.
Sorry lX and don't use it alot.
imnukensc
BX2380
Sep 10, 2015
651
532
Midlands of SC
isn’t that showing the transmission drain plug and the two plugs in the rear axle case?
Yes, it is. Apparently the OP can only look at pictures, but neither read their captions or the instructions that go along with them. As he said earlier, he's "a mechanic." And I said, "I'm glad you're not working on anything I own."
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
Many report this manual as suspect in many ways, Did they pay YOU to write it, China wages.
