Bearing support shaft
Floridaman
26
Florida
A 1.5" steel shaft and two pillow blocks?
i wasn’t sure if the pillow lock bearings would be able to handle the speed (2800 rpm) or side load I would need to put on it. I’ve always seen them in low speed applications. I was looking at over hung load adapters, which appear to be beefier than the pillow blocks.
6,792
$32
4000 RPM
4000 LBF STATIC LOAD
6600 LBF DYNAMIC LOAD
$68
1045 TGP SHAFT
ANSI 3/8" KEYWAY
You can probsnly get both from Surplus Center
10,571
No... WHAT? As in What are you trying to do?
Lots of different scenarios for a bearing and a shaft.
1 1/2 shaft size is HUGE!
You building a D9 CAT?
