Ballast box
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
Your BH77 backhoe will be great ballast. If you swing it to the side, the rear clearance isn’t bad either. I usually have either my BH77 backhoe or my box blade on if I need ballast. I have never really considered having a dedicated ballast. But if you need the extra clearance in back …..
Jack
Ditto. Heavy ballast box would be great if I needed for space concerns, but I've not needed extra space back there so far. I leave the BH on most of the time and since it's back there I find all kinds of uses for it.
Steamer Pete
LX2610
Mar 29, 2021
49
42
Holland, MI
Made mine last year from a slightly used 10x24x30 electrical panel, TSC draw bar, some angle iron, and a 2" receiver. The draw bar is bolted thru the back of the panel with long bolts so the heads would be well burried in the concrete. Calculates out to about 550 lbs and works great. Zero issues with the rear end getting light on my LX2610.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
That’s definitely pretty sweet! I guess before now I hadn’t considered a general purpose tool carrier on top of having the extra weight for using the loader.
I’m also curious if others use fluid filled tires?
I have rim guard filled tires + ballast box the grapple + curl breakout force allowed me to pickup a log the FEL couldn't lift
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
214
187
Westford, Massachusetts
shelkol.com
I should run a hose from mine into the cab. Get people wondering if I'm sober. A beer keg with 600# of lead
RalphVa
738
322
Charlottesville
Even a light RB is enough. A sales guy brought the Woods BB by last week and used a strap around the BB and FEL to lift the 518 # thing off a pallet in the back of his F-150 with the B2601 and only a light Frontier RB2048 on the back. Rear wheels were supposed to be loaded. I haven't check them yet. Probably are.
The Woods unit was all the way in front of the FEL: lots of weight way out there.
Trapper Bob
L4701, Wicked grapple, 7’ box blade, 6’ Wicked bucket, SVL 65-2 w/4 in 1 bucket
Jan 17, 2022
446
819
Andover, KS
I needed some ballast for a grapple. I also wanted a carry-all/work platform, so I combined the 2. The 4x4 box steel is filled with concrete. I had a couple mis-matched wheel weights that I made a cradle for to carry under the plat form. I can removed the wheel weights fairly easy by removing 2 bolts, setting on the ground, & driving away. I have about 650lbs or 350lbs or nothing as needed.
I’ll paint it when I’m done adding to it.
