B7100 Piston Installation
3,155
You will have to rotate the engine numerous times to get the marks to come back into alignment.
While that may be what you want to do, would it just be easier to remove one of the gears and set the timing correctly per the manual?
Did you remove anything under the front cover or is it still set like when it was running? If you didn’t change anything the I assume it would still be correct unless there is a broken gear or something.
torch
Jun 10, 2016
2,886
1,133
Muskoka, Ont.
Torch,
I did recheck the compression with the Schrader Valve you suggested and no difference.
Do you think my assumption about lining up the timing marks is correct?
Thanks, Larry.
I've not had the pleasure of doing this on a B7100, but if I understand correctly with #1 on TDC of compression stroke the crankshaft gear timing mark should be at 12:00, aligning with the idler gear timing mark at 6:00. The cam gear timing mark should be aligned with the idler gear tooth (not a mark) at about 7:30 and the injection pump gear timing mark should be aligned with an idler gear tooth at about 2:00 (not a mark).
Wolfman or one of the Kubota mechanics will jump in here if I have that wrong.
Schmotown
B7100 HST D
Oct 17, 2024
MI
Thanks for your reply. It looks like Russel has replied with the answer.
Schmotown
B7100 HST D
Oct 17, 2024
MI
Russell, you are correct on how to reset the timing and no, I haven't touched the gears inside the cover.
My goal was to recheck the gear timing because I am going to pull the engine for new liners due to my 300 psi compression readings after new parts.
If the original timing was "off" when I bought this tractor last fall that would also help explain my low compression. If it is off then I will reset the timing and reassemble the tractor and take new compression readings. If I can verify that the timing marks are correct then I am blaming the original liners and I will continue disassembling the engine to get it ready for new liners. Hope this better explains my plan.
Thanks, Larry.
Schmotown
B7100 HST D
Oct 17, 2024
MI
#40 Fan, attached is a pic of the timing gears showing that the timing marks are correct. Piston is at TDC and the push rods were in the correct position for a piston that is at the top for the compression stroke.
Oddly, there is no timing mark on the front or the back of the gear on the crank. I'll order a new gear prior to reassembly so I can be sure that the timing is correct for the repaired engine. Hope this helps.
Regards, Larry.
torch
Jun 10, 2016
2,886
1,133
Muskoka, Ont.
Regards, Larry.
I think you forgot to attach the picture
11,267
So you'll need to pull the crank gear and look at both sides closer as there will be a timing mark that is hiding.
11,267
Note that the keyway on the crank will be down when it's set up properly.
You will need to remove the collar and the washer in front of the gear to see the timing mark.
Unless the gear has been installed backwards.
#40Fan
660
489
North, he mentioned there wasn't a mark on the back or front of the gear.
Schmo, do you have a work shop manual? I would think that you picture shows the correct orientation for everything, but I'm wondering if the manual states anything about where the woodruff key on the crank snout (if there is one) should be located when everything is in time. If there is one, where is it located in the picture you posted? 12 o'clock, 6, etc?
11,267
Like i show in the pictures the mark hides till you remove the collar and washer, he hasn't done that.
And the keyway slot is about 6:45 to 7:00, so not a way to set the timing.
11,267
You will need to pull the collar forward and the washer behind it forward to see the timing mark.
Schmotown
B7100 HST D
Oct 17, 2024
MI
Thank you both for your input but I have already removed all of the gears except for the crank gear however, the
Thanks you both for your input but I already pulled all of the gears except for the crank gear. However, the keyway on the crank gear is in the position shown in Wolfman's pics so possibly the timing was correct. In the future I'll be more patient and wait for input before moving forward.
I didn't pull the sleeve or washer as I wasn't sure how to remove them and I thought the dealer could remove them when the block is in their shop. I don't have an engine stand any more so my plan was to send the block stripped of everything but the oil pan, crank and pistons and have them remove and reinstall them after the liner work is complete. That way I could bring the block home and reinstall it into the tractor and finish the reassembly then. Does this sound like a sensible plan? If the dealership doesn't have a hot tank to clean it would move on to another shop? As far I can see with my borescope there is very little build up in the water passages.
Best Regards,
Larry.
11,267
Most shops will not accept a block that is not completely stripped.
You also risk them losing parts.
You can set the block on it's top (just pull the oil pin pipe) and remove everything from the bottom.
Schmotown
B7100 HST D
Oct 17, 2024
MI
Okay, I'll do that. Do you have a guess as to how much the block weighs? Thanks, Larry.
Schmotown
B7100 HST D
Oct 17, 2024
MI
There is an "Idle Assembly Apparatus" on the back of the injection pump casting and it appears to be tamperproof. Can this assembly be left in the block when it gets sent to the machine shop for new liners? There is a spring that protrudes from the assembly and I imagine it is the return spring for the rack. Can that spring be pulled out? It may just be stuck.
I'm having difficulty removing the fuel camshaft. The rear bearing does not slide through the bore for the front bearing. Is it just a tight fit that may need a bit of persuasion?
Thanks, Larry.
11,267
Pull the idle aparatis, just pull it using the nut closest the block.
On the fuel cam have you removed the bearing keeper?
