B6000 problems maybe oil
Kubota b6000
B6000
Aug 1, 2015
14
Colborne, Ontario, Canada
http://www.ebay.com/itm/NEW-KUBOTA-...POWER-UNITS-/181342903082?hash=item2a38e11b2a
That one on ebay has 5 terminal mine has only 2. Does that make a difference?
In addition the wiring is really bad. Many broken or cut wires, purposely I think, Many wires need to be replaced.
if you have basics in using analog/ digital multitester test your ignition switch or smell it is burnt replace it..
Yes I do have one and I will get at it as soon as I figure out which wires to replace and/or the rectifier.
7,260
Start following the wires from one point to another. ;)
Jim L.
856
162
Old style of a connector symbol. The triangle is the male, and the box the female.
May be a bullet type of connector.
7,260
Yep just like Jim said they are bullet connectors. ;)
Kubota b6000
B6000
Aug 1, 2015
14
cbaker65
Kubota,gras hopper,john deere mowers.
Aug 5, 2015
9
Mcfarland,Calif.
Well I tested many wires and they all show 12 volts. I will check a few more things today but I get 12 volts across both terminals on the main switch. There are so many things cut or removed it is hard to find where the wires go.
I hate to ask,or say it,But have you checked the fuel system,an
water seperator?
Dont know if the tractors have them,but are mowers do...If so,
check for any relay switches or fusable links..
