http://www.ebay.com/itm/NEW-KUBOTA-...POWER-UNITS-/181342903082?hash=item2a38e11b2aThank you Kubotasam. I will have a go at taking the dash of and poke around
Yes I do have one and I will get at it as soon as I figure out which wires to replace and/or the rectifier.http://www.ebay.com/itm/NEW-KUBOTA-...POWER-UNITS-/181342903082?hash=item2a38e11b2a
That one on ebay has 5 terminal mine has only 2. Does that make a difference?
In addition the wiring is really bad. Many broken or cut wires, purposely I think, Many wires need to be replaced.
if you have basics in using analog/ digital multitester test your ignition switch or smell it is burnt replace it..
Yes I can jump the terminals on the starter and it turns over but does not start.Does it turn over? if not is the PTO in the off position, if not turn it off.
Battery charged?
Thanks North Idaho Wolfman I have this diagram but there are a couple of symbols on it that confuse me, like the small arrow pointing towards what looks like a rectangle? There are 3 of them on the generator.Start following the wires from one point to another.
Well I tested many wires and they all show 12 volts. I will check a few more things today but I get 12 volts across both terminals on the main switch. There are so many things cut or removed it is hard to find where the wires go.http://www.ebay.com/itm/NEW-KUBOTA-...POWER-UNITS-/181342903082?hash=item2a38e11b2a
I hate to ask,or say it,But have you checked the fuel system,anWell I tested many wires and they all show 12 volts. I will check a few more things today but I get 12 volts across both terminals on the main switch. There are so many things cut or removed it is hard to find where the wires go.
Thanks cbaker65 But I do not see any fuel related on the Wiring DiagramI hate to ask,or say it,But have you checked the fuel system,an
water seperator?
Dont know if the tractors have them,but are mowers do...If so,
check for any relay switches or fusable links..
Lol...yea I know,I just thought I would throw that in there!...Thanks cbaker65 But I do not see any fuel related on the Wiring Diagram
