NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
Its 22 degrees outside. I was actually looking forward to using the snowblower today after using the blade the last few storms we had. I was just about done with the drive and just as I was approaching my garage, TONS of black smoke came billowing out of the tailpipe!
I slowed it down and shut it off to take a look and I saw that the entire front end was covered in snow. I opened the hood there was snow all over the engine.
I know that from my poor experience with the 3350 that they want you to remove the front air intake tube because it was interfering with the DPF filter's temperature. It wasn't hot enough. I know that they were going to install a "snow skirt" as one of their fixes.
Thats when I decided to take a closer look at the air filter. JAMMED with snow!
I took off the air tube and replaced both inner and outer air filters. When I looked in the tube it appeared dry. My concern is that water got in there. I don't know what black smoke means. Will it be OK after I let things dry out a bit? I started it up again and it turned over no problem. Does it need to be looked at?
I had a heater installed in the garage so I turned it up to dry things off a bit.
The screen and the radiator was jammed with snow too. I had to wait for the snow to melt before I could remove the screen, it was froze solid. I think I want that snow skirt installed after this happened.
What do you guys think?
