advise on shed roof trusses diy
top gnome
Dec 12, 2021
461
218
Fundy shore nova scotia
FWIW: I built a garage this summer and ordered trusses. They were factory made and approved by an engineer. I'm in a region where we get lots of snow.
They are 30' long with a 6/12 pitch. All built with simple 2x4s. I have 1 truss every 24".
I actually had to build and extra one myself since my design changed and I made the garage 2' wider. Like @Old_Paint said, I used little pieces of plywood instead of the metal things on every joints. The metal ones are expensive.
Hi I have two builds going this small shed and a 20x24 tractor shed that I am woefully behind on. I did purchase the trusses for the tractor shed in June but will not get them until October. I tried to order the trusses for the small building but the delivery date was end of december. that is why I built these.
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
290
188
ottawa
Yeah, it's a good thing to build them yourself. You'll save a lot. But it requires more patience.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
752
655
E.
a word of warning..... if you live where I think you live given you live in an area that gets upwards of 8' of snow a winter (8 feet!) i don't think I would take a lot of advice given in this thread.
If I am wrong on your location then shame on me.
be careful, better safe than sorry
Old_Paint
Dec 5, 2020
1,791
1,827
AL
Not only are they expensive, unless you have a press to install them, you’re no better off than toe nailing. Even if they’re properly pressed, they still require nails or screws to make sure they don’t peel and loosen the joints.
Glue on plywood gussets serves the same purpose as the barbs on the metal joint plates, and does need a press. That plus 3 screws in every timber at every joint, I don’t think mine are gonna come apart.
OrangeKrush
Nov 15, 2020
1,044
514
Indy
He came here seeking advice and was given good advice in my opinion. If he ops to use it great if not that's up to him. It sounds like he's doing most of what needs done.. adding the gussets is of major importance.. both sides would be best! If it were me I would put an extra 2x4 angle from bottom center upright to top cord at a 45* as I showed in earlier post.
Add a stringer nailed on edge (upright) against the center uprights at bottom, end to end of building. This will tie the center of walls and gables together and help strengthen up the bottom cord. Lastly run a diagonal from that center point of gable out to your side walls on top of your bottom cords.. 45* work great! This will stabilize your end walls.
The only thing I'm not sure about is the plastic on the roof. If it's going to be on the whole roof I would run purlins flat and less than 24" on center.
Steamer Pete
LX2610
Mar 29, 2021
Holland, MI
Made some for my sheds in the past. Couple things: 1) Lay out the pattern on your driveway with chalk lines and build to those. 2) Mark the same end while laying on the driveway, and assemble on the building with all the same ends on one side. Flipping occasional rafters can amplify any variation once the decking starts to go on. 3) 1/2" plywood plates and lots of nails or screws, and glue, at all the joints, both sides.
awesome
Sep 16, 2018
290
188
ottawa
Actually, instead of chalking it on driveway: build one as best you can. Then use it as a template. Nail each new 2x4 over the template and then make sure it aligns perfectly before putting toe nails. This way you'll have identical trusses.
It doesnt really mattrr if your truss is ugly, what matters is that they're all equally ugly. They need to be identical.
5,528
9' trusses can be built on a 4by8 worktable... I did 36 of them years ago..all the same as the first,so either they're all right or all wrong....... since sheds are still standing I'll go with 'right';)
5,129
Trusses built by amatures are not permitted in most areas!
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,065
1,681
WestTn/NoMs
I talked to my county planner in north Miss. They make a strong distinction between occupied and unoccupied space. For unoccupied space, I have to get a permit, but anything goes. For occupied space, engineer approved trusses are required. So I can design and build trusses for a shop/garage, but not for a home.
top gnome
Dec 12, 2021
461
218
Looks real nice. I see a couch? I'm guessing a TV as well?
we have a screen gazebo and that is part of the furniture for that. no tv the building will not have power. my wife will craft in the summer and it will store the gazebo furniture in the winter.
top gnome
Dec 12, 2021
461
218
here permits are issued by size. this building did not need a permit it is under 214 ft. I believe building your own trusses is frowned upon as the mending plates are stamped do not use for trusses and truss mending plates are not available. I will say that the lumber in my trusses is much much better than the ones I just purchased from the professionals.
5,528
My SIL lived in a 9by12 'bunky' like that for a year+. Cost her $10K+......
locally here, trusses need a 'stamp of approval' and anything over 110 sqft MUST have a building permit.....
My 9by12 tractor sheds didn't need permits, hehehehe. Each cost $500 in materials 7 years ago, Gave 3 of them to neighbour last month as city says 'no structures' in front yard
