A GR2120 or BX1880?
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
957
923
Amsterdam, NY
Sorry I just found 70 series wheel base is shorter so it wouldn't be the same as 80 series. What I was looking for is if you turn left as hard as you can and make a full circle while mowing what is un cut diameter left. Thank you
The turning radius (uncut) is 7.5 feet.
7,162
I am in a bit of a conundrum as I am trying to decide what would be the right machine for my needs.
I have a half acre of property in the Northeast that wasn't well maintained at all by the previous owner so I want to fix that and bring it up to its potential. The property is nice and flat up front but the backyard has multiple hills that range from 12-20 degrees (measured) and the trees and brush are quite unruly back there but all in the back leading to a large pond. There is little in terms of obstacles outside the rear of the property. I've already had many wildly overgrown bushes and stumps removed and ground down. I plan to use the machine to mow probably 80% of the time but will tow a utility cart to move brush, cut up felled trees, firewood and soil, tow a lawn sweeper and use a plug aerator to help bring some life back to the lawn. The towing on hills does seem to steer me toward AWD/4WD. There is a decent section that needs a lot of clearing with chainsaws and it can be tight. I'd also like to use a leaf collection system to collect all the fallen leaves from the mature maple trees as well. Additionally, the lawn feels a bit soft and spongy and the backyard also has a leetchfield. I'd rather not leave ruts in the lawn if possible.
I gather that most big box store stuff won't last doing what I want to do on hills and towing. I do like Kubota and these seem to fit my needs. The green paint tax seems like a lot for an X7 series as well though one very capable machine! With a lot of thought, I am not seeing the need for a FEL in my future. With what I said, which seems to fit the best?
These two seem to fit well for my needs, close in price but are two different classes. Any help and guidance before checking them out would be appreciated.
Also, I do not need a snowblower attachment as I have Honda snowblowers for that.
Thanks for your help!
If you need 4wd (and I do) its not even close.
I have a G2160 and G2460 - both very rugged and capable lawn tractors that beat the snot out of a box store grade machine. Both mow great but both are 2wd. There are large sections I cant safely mow with them.
I would happily trade both for a BX with 60" mid mount mower just for the 4wd. I have no need or desire for a midget loader and would not spend extra for a machine with one.
PaulL
B2601, MX5200.
Jul 17, 2017
2,788
1,784
NZ
I seem to recall a video - maybe Messicks - showing how to adjust the stops on the steering for the BX. It looked like they allowed materially tighter turns.
Bee-Positive
Nov 16, 2022
957
923
Amsterdam, NY
I interpret the turning radius as the tire tracks, the deck (depending on size) would stick out past the tires a bit and reduce the diameter of uncut grass ...
I went out and did two circles left and two circle right (4 total).
BX1880, turf tires, 54" mmm.
The uncut grass measured:
Turning right = 6' - 6"
Turning left = 8' - 6"
So yup, 1 foot less than tire tracks only.
