A GR2120 or BX1880?
STS_EA888
Kubota W5019-PC, Honda HS55
Apr 3, 2026
9
14
New England
I am in a bit of a conundrum as I am trying to decide what would be the right machine for my needs.
I have a half acre of property in the Northeast that wasn't well maintained at all by the previous owner so I want to fix that and bring it up to its potential. The property is nice and flat up front but the backyard has multiple hills that range from 12-20 degrees (measured) and the trees and brush are quite unruly back there but all in the back leading to a large pond. There is little in terms of obstacles outside the rear of the property. I've already had many wildly overgrown bushes and stumps removed and ground down. I plan to use the machine to mow probably 80% of the time but will tow a utility cart to move brush, cut up felled trees, firewood and soil, tow a lawn sweeper and use a plug aerator to help bring some life back to the lawn. The towing on hills does seem to steer me toward AWD/4WD. There is a decent section that needs a lot of clearing with chainsaws and it can be tight. I'd also like to use a leaf collection system to collect all the fallen leaves from the mature maple trees as well. Additionally, the lawn feels a bit soft and spongy and the backyard also has a leetchfield. I'd rather not leave ruts in the lawn if possible.
I gather that most big box store stuff won't last doing what I want to do on hills and towing. I do like Kubota and these seem to fit my needs. The green paint tax seems like a lot for an X7 series as well though one very capable machine! With a lot of thought, I am not seeing the need for a FEL in my future. With what I said, which seems to fit the best?
These two seem to fit well for my needs, close in price but are two different classes. Any help and guidance before checking them out would be appreciated.
Also, I do not need a snowblower attachment as I have Honda snowblowers for that.
Thanks for your help!
jyoutz
Jan 14, 2019
3,595
2,700
Edgewood, New Mexico
Get the BX. Far more useful and durable than a garden tractor.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,412
615
Richmond, Virginia
4WD 99% of the time is a godsend. Bagging clippings, you have to deal with the powerhead. A rear PTO mount keeps the tractor more narrow.The GR (like the green) hang it off of the side) A mower has a significantly tighter turning radius. A tractor is generally more versatile. I use the FEL A LO\T!
I was faced with the same dilemma six months ago. I payed the piper and got a green X754 AWS. Actually larger than my BX25D!!! But all wheel steering.... I did have it upgraded with a rear PTO, 21 bushel power bagger and a 3pt just in case. Buy once, cry once.
I now have both as I did not want to spend the time swapping implements during 'work season' and the green is able to make the tight turns.
If finances were tight, I'd get the tractor with a FEL and 'Big Box Store' garden tractor (biggest engine you can get) knowing in a few years you are going to upgrade.
Grandad4
Apr 5, 2016
424
183
Greensboro, NC
If you're a hands-on kind of guy (or gal), get the BX - AND the loader. Following years of lawn tractors, I bought and used a BX that. outworked those other gadgets many times over.
The loader... well think of it as a sidekick that can bench press 500 lbs all day long without tiring. The list of chores where that can be useful is limited only by your imagination. It is expected that you add some weight to the back of the tractor for balance, but it is well worth it.
Learn how to mount and dismount the loader as needed. With practice it's an easy task.
Bearcatrp
Mar 28, 2023
1,324
966
Minnesota
If you go BX, do not buy without the FEL. You can unhook it and leave it in the garage until needed. It will be hard to sell without a FEL in the future. BTW, the 4 wheel drive is fantastic on my BX1880. Saved my bacon many times.
GrumpyFarmer
5,055
IMO, the BX is a diesel powered wheelbarrow if you get the loader.
If you simply want to mow, zero turn is superior.
If you want the all purpose utility there is no comparison. I’ve said before it should be illegal for a dealer to sell a BX without the loader and someone got their feelings hurt onto this forum (I believe they are gone now 😏)…but I a semi serious about that in a Snarky way.
The loader really opens up possibilities to of the utility / capability of the BX…forks grapple loader bucket plus pto on the back.
It’s like a mullet…business up front party on the rear. 😂
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
398
178
Southern Worcester County, MA
I had the same issue when I was deciding. For a few thousand more I bought a much more capable machine. The BX2380 has been nothing short of awesome for me. Overkill for my 1/2 acre but oh so nice having a loader to do so many things.
airbiscuit
Mar 18, 2021
389
446
NW WI
I'm not a fan of sub-compact tractors, but it seems about right for your needs. My neighbor has a GR2120 and I am impressed. It is 4wd, and he effortlessly blows 12" of snow. It will do all the tasks you describe and put a smile on your face.
That said, I think you might reconsider the value of having a loader. It turns your tractor into a Swiss army knife. You will use it to do a hundred things, only one of which is moving dirt. I don't know anyone who bought a tractor and loader, who regrets buying the loader. I do know people who just bought a tractor, and wish they had bought a loader (unless you need a 150hp tractor to run a baler).
Shawn T. W
Dec 9, 2024
714
1,346
SW Missouri Ozarks
I agree with a loader is VERY HANDY, lots of stuff that it can do to not only make your life easier, but possible!
With that said ... While I do have a loader (and backhoe too!) I also have a different tractor without a loader, and actually looking for a third tractor without a loader too!
I don't think a loader is required on every tractor, but will say that a non-loader tractor is much harder to sell for a good price compared to what you paid for it, whereas if it has a loader, there is nowhere near the price dump! But ... That means I can buy a non-loader tractor very cheap!
Of those two choices I'd get the BX with a loader ... Add the Backhoe if you want a truly Swiss Army Knife Tractor! (Might have to bump engine size though!) 😂 It's only money! :cool:
Bearcatrp
Mar 28, 2023
1,324
966
Minnesota
Look at this way. Can you lift 600 lbs? My BX 1880 with forks had saved my poor back many times. The BX line of tractors is a great sub tractor for less than 10 acres of land. Gets the job done!
Shawn T. W
Dec 9, 2024
714
1,346
SW Missouri Ozarks
I live alone ... My little Swiss Army Knife Tractor has made my life much easier ...
I had this old rescued cattle panel that I was using to "double up" to to make the openings smaller, to help protect my barn cats, that protect my tractors from rodents, I wasn't strong enough to push it in tight/close enough to be able to pound in the fencing staples ... I used the forks to be a "helping hand"!
Same project ... Try to lift a floppy 16' wide cattle panel in the wind, and hold it while you pound in the staples by yourself!
Now my kitties have a safe place to eat and sleep without worries about coyotes or stray dogs!
Forks are the next step, after rear ballast ... 😂
STS_EA888
Apr 3, 2026
9
14
New England
Thank you for the responses thus far! Please keep them coming. This will be my first major yard equipment machine outside of my Kubota W5019. It seems to be pretty one sided for the BX1880. This forum has been much more helpful than other places I've asked machine questions and no one responds. I like to be as informed as possible from those who own one or similar before talking to any salesman about my needs. I am pretty handy myself and can do a whole lot on my own and have those who I can ask to help and or teach me if I don't know. The loader likely would help a lot with heavily overgrown brush clearing and pulling out felled trees.
I don't have a place to store one inside unfortunately so it would live outdoors but it looks like covers are available to keep rain, snow and bird crap off of it.
PaulL
B2601, MX5200.
Jul 17, 2017
2,775
1,774
NZ
Definitely get the loader.
Also consider the BX2380. It's really not much more money, and would have better resale. I realise we're spending your money, not ours. And the BX1880 is also a great machine - so it's not "get the BX2380 or nothing", it's more that you get a bit bigger wheels, a bit more power, and better resale, for what's probably an extra $1-2K at purchase.
For the tasks you describe, you'll be amazed how much a loader helps. It lets you modify your land to make it like you want, rather than just dealing with the hills, lumps and bumps that it comes with. Lifting brush that you've cut, and just moving stuff from place to place, it's amazing what they're useful for. Putting dirt in the trailer. Lifting things off the trailer. Putting your better half up in the bucket to clean the gutters, trim the trees, pick the fruit. Moving mulch and landscape timber. You never need a wheelbarrow again.
Shawn T. W
Dec 9, 2024
714
1,346
SW Missouri Ozarks
Not sure if you have the rotten invasive species multi-flora roses or not, but my place was overgrown with them! If they were too big to back the brush hog over them, I'd drive into them with the loader at ground level, and uproot them!
Tossed it out of the way, mash it down some with the loader, then was able to run over it with the brush hog and mulch it up!
Went from this old overgrown "pasture" ...
To this!
From this ...
To this ...
To this!
Forks are handy too!
This Sub-Compact Utility Tractor (SCUT) is similar size to a BX 2380.
Bearcatrp
Mar 28, 2023
1,324
966
Minnesota
PaulL is correct on this. I had to buy tires for the 23S in order to get R4 tires. Someone posted awhile back about doing this. The axle on the 1880 has a marking 23S on it. Works great. Gave a about a 4 inch lift. The BX line of tractors all have the same lift capacity. Just different size motors and tires.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
315
500
NC
I had an L2501 and Husqvarna riding mower with a Kawasaki engine, but I'd used the L2501 for all of the large projects on my small parcel, so it was time to downsize. The riding mower was too small for my needs (similar to yours), but the L2501 was too big. I narrowed the options down to a Deere X7xx or BX, but ultimately ended up with a BX25D with both the loader and backhoe since I stumbled into a deal on a lightly used one that was way too good to pass up. I agree with the others that a loader and forks are invaluable, and while I don't need the backhoe often, it's been handy a few times. The BX mostly sees lawn mowing duty, and it doesn't have the turning radius of my old basic riding mower, but it's close enough to not be a deterrent. 4wd was needed for my sloping land for both towing and plugging purposes. The biggest benefit I've found is how much more fuel efficient the diesel is than my old gas mower!! It does 3x the mowing per gallon than the old mower, despite being notably larger. I mostly do loader work in the off-season, but the loader is quick to put on and off, so instead of buying bags of mulch, I'll just have a load delivered and spread it with the loader. Just the other day, I had a few fire doors delivered. Strap to the forks and they were on their way without me having to lift anything heavy. Simple tool to make your life easier.
Another factor for me was future resale. I sold my L2501 for what I bought it for new after using it for 5+ years, so I knew how strong the resale of orange is.
Shawn T. W
Dec 9, 2024
714
1,346
SW Missouri Ozarks
Have you measured this?
If the tires are only 2" taller, that means your axle is only 1" higher, so 1" more ground clearance ... Inorder to have a 4" lift from larger tires you would need 8" larger tires, like 32" similar size to the B models.
Shawn T. W
Dec 9, 2024
714
1,346
SW Missouri Ozarks
For the OP, smaller tires will keep the tractor a little lower center of gravity for steeper terrain, and easier to get on and off, but limits the very limited ground clearance it has ... Also smaller tires will give a slightly harsher ride, as there is no suspension on these tractors ...
A few more pictures for the benefits of a loader, even if all you have is the bucket ...
Scoops gravel ...
Even rocks! 😂
Pulls T-posts ... I added hooks later from @Kennyd4110 at Kens Bolt On Hooks. ..
Dug a little "ditch" with the help of the Bxpanded Piranha Tooth Bar ...
Trailer mover, plus new hooks a tooth bar! (I've since moved the 2" hitch to the bottom of the lip)
Cleans out ditches!
Lawnmower lift!
Yes, it's an "expensive wheelbarrow" but it hauls yard debris just fine!
And yes, it also scoops and hauls bulk bark mulch just fine, so you don't gotta buy the expensive bagged stuff ...
Reactions: 6 users
Shawn T. W
Dec 9, 2024
714
1,346
SW Missouri Ozarks
And ... If that's not enough reason to have a loader on a tractor ... Here are a few more ... Sorry I'm bored this morning sitting in a truck stop in a little border town in California ...
Animal transport ... !
Hauls all kinds of stuff!
Spring stick cleanup ...
Even snow!
Great for carrying tools and supplies!
Back saver, very adjustable height!
Hauls your embarrassing mistakes!:oops::rolleyes:
Even hauls leaves!
A loader is just too handy to not have!
