A GR2120 or BX1880?
STS_EA888
Kubota W5019-PC, Honda HS55
Apr 3, 2026
9
14
New England
I'm going to try to get to my rather nearby Kubota dealer this afternoon before they close but that may be pushing it for both me and them time wise. If not, will do it tomorrow morning and explain my needs and some wants and see what they offer. The BX with a loader seems like a clear winner in this and they have an Orange Days sales event going on which is outstanding. I saw the Pirhana Bar bucket attachment which looks to be exactly what I need to clear and move a lot of brush easily. They have both a BX1880 and 2380 in stock and now determine what is best for needs, use and the terrain I have. Is a BX2380 too much? Outside of rear PTO-driven leaf collector (which I will get in the fall) and maybe renting a tiller to help level some land, I have not seen a need for the extra PTO muscle.
PaulL
B2601, MX5200.
Jul 17, 2017
2,788
1,784
NZ
They do a lot of the same job. It's more that the BX2380 is the "standard model", and the BX1880 is the one they shrunk, the BX2680 the "more power" version. For some tasks the BX1880 may be underpowered, and the resale is a little harder. In reality both are 100x better than doing things by hand. It's just the BX1880 might actually be 98x better and the BX2380 102x better.
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,350
983
Minnesota
FEL lift lbs is the same on all the BX. The 3 point lift lbs is more on the2380.
Shawn T. W
Dec 9, 2024
766
1,399
SW Missouri Ozarks
I run a 48" tiller behind my 19.6 PTO HP tractor, it has no problems, the one HUGE advantage to a HST is that you can go as slow as you like, which is handy if you are HP challenged in tough soil with a rototiller ...
Those who have first hand knowledge can tell you better, (As I don't have any, but I read a lot) but it's my understanding that the 18 is a better mower than the 23/26 as it's lower and has better stability, but the way the mower interaction with the ground is, that's it's more of a "lawnmower " than the other slightly higher ones, and I'm not sure if the 18 has the quick and easy mid-mount mower (mmm) removal system as it's bigger brothers have either ...
However if you think you need that extra 1" of ground clearance for going out into the brushy rough terrain, the 23/26 might be a better choice, but nevertheless look into a skid plate guard for the transmission cooling fan which can be RUINED by a stick, on any of these models!
Go drive both! For really uneven terrain you can add rear wheel spacers, but the mmm can limit that to some degree.
Personally I always go with the biggest engine they can stuff in the same sized frame! But realistically I run out of traction, long before power!
STS_EA888
Apr 3, 2026
9
14
New England
I went to a dealer this morning, who also sells New Holland, to speak to a salesman and just stated my needs and wants, what kind of property I have as I did here to see what was recommended and the first thing he said was a BX. He took me out to the one on the lot that was easiest to look over and drive which was a 23S. Obviously ignored the backhoe on it but drove it about the lot, tested its maneuverability and everything on it. Very impressed and I really liked its small size which will be great for my property. The controls all seem intuitive, easy to operate and it fits my lanky, gangly frame well. Apparently the seat height on a 23S is a little taller than the others and I'd prefer a slightly lower seat. In all, it seemed like a better machine to me than the Deere 1023E that I also tried.
I guess now I just have to determine which would be best of the two, a BX1880 or a BX2380. Is the about six more horsepower really needed for $4K more for what I would use it for? I would like to get Kubota's rear PTO-driven GCK60-23BX grass/leaf collector in the fall.
10,888
The BX2380 is a whole lot more tractor than the BX1880!
PaulL
B2601, MX5200.
Jul 17, 2017
2,788
1,784
NZ
If you want a rear bagger, my understanding is they eat quite a bit of HP. I also think the 1880 is 54 inch deck only, the 2380 can be 60 inch. Cutting grass takes HP, adding a bagger as well takes more.
I'm sure the 1880 will do it. The 2380 will do it better.
Sawdust&Shavings
BX1870,LA203A,BX6315,BX2767,RCK48-18BX,GCK60-23BX
Apr 25, 2023
208
248
Stafford, VA
Horsepower is king; however my BX1870 has no problems running its RCK48-18BX mid-mount mower and the GCK60-23BX bagger at the same time…that little diesel has plenty of torque to handle them.
Sawdust&Shavings
Apr 25, 2023
208
248
Stafford, VA
That's a 48 inch deck, right?
Yes, the RCK48-18BX is a 48” deck. While a 54” or 60” deck would have cut the same amount of grass quicker and since the mmm deck edges would stick out a bit more on each side of the BX making trimming around the raised beds and other obstacles easier, I can just fit the 48” deck between our raised beds which I built for my old machine with a 46” deck. If I could have used the larger deck I would have purchased the BX2370 or possibly the BX2670.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
946
916
Amsterdam, NY
I mow a couple acres, in-between plant beds, around the house and deck, trees, propane tank, etc. with a 54" deck and have no complaints.
Rear lift capacity 24" behind the lift points on both the BX1880 and BX2380 is the same 680 lbs.
One difference is the BX2380 has 4 more hp at the PTO (14.7 vs 17.7). Doesn't sound like a lot but even a little more is better.
Bearcatrp
Mar 28, 2023
1,350
983
Minnesota
Only the 3 point lift lbs, height due to larger tires and the PTO is different between the two BX's. If you have the bucks, suggest you go with the larger one but the small tires on the 1880 do come in handy.
STS_EA888
Apr 3, 2026
9
14
New England
The salesman is recommending the BX2380 due to the slopes in the yard. Suppose that would be nice if doing ground engaging work on those said slopes. Will have to give that some more thought. I suppose having the extra horsepower would be nice if projects do become larger and running more things.
Bearcatrp
Mar 28, 2023
1,350
983
Minnesota
Usually better to go larger for future projects.
PaulL
B2601, MX5200.
Jul 17, 2017
2,788
1,784
NZ
You have a smallish property. I'm not convinced on slope being a reason for more HP, the BX is traction limited not HP limited, even in the BX1880.
I'd personally get the BX2380, but really it comes down to whether $4K is a lot of money in your budget. If you can stretch to it I'd do it, I don't see that you'll ever regret it. If you can't afford it, the BX1880 will do everything you need, just you may have some days when you think "I wish I had a bit more power".
Shawn T. W
Dec 9, 2024
766
1,399
SW Missouri Ozarks
I'd also image the 23 will be easier/quicker to sell than the 18 ...
STS_EA888
Apr 3, 2026
9
14
New England
I'll go run some numbers on this as this morning the dealer gave me quotes for both with a loader, 54" mower deck, and Rim Guard for the tires and price difference is $3K. Thank you to all for your help! Its been great to hear from those who actually have and use them and their experience.
I'll let you all know what I decide to go with.
notme
PA
I'm considering a 1880 with a 48" mower can you tell me what the uncut diameter is?
Sawdust&Shavings
Apr 25, 2023
208
248
Stafford, VA
I haven’t a clue what you are asking for…what’s an uncut diameter? Here’s the specifications for mowing decks up to the BX70 series:
notme
PA
Sorry I just found 70 series wheel base is shorter so it wouldn't be the same as 80 series. What I was looking for is if you turn left as hard as you can and make a full circle while mowing what is un cut diameter left. Thank you
