3 point quick hitch
Hugo Habicht
G1900
Jun 24, 2024
1,437
2,017
Ireland
Perfect ! (y)
How do you cut that thick material? Is there a professional laser cutting machine hidden in the basement? :)
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
453
699
Baranduda, Victoria, Australia
Perfect ! (y)
Thanks Hugo. No laser cutter unfortunately. I'll take a couple of pics of what I use tomorrow - nothing fancy.
Paul Allwood
Jul 8, 2025
453
699
Perfect ! (y)
Here are the tools I used to make the hooks out of 25 mm flat mild steel. Nothing fancy, but it works.
If I can I'll use the Bosch steel cut-off saw. The blades are expensive but it works really well. I was sceptical at first but now love it. I built it into a frame that supports the pieces I'm cutting and also allows the saw to rotate up to 45 degrees so pieces are still supported by the bench for angle cuts.
With a new blade it cuts through 100 x 25 flat bar in about 20 - 30 seconds. It cuts through RHS like a hot knife through butter.
The cut here is cleaner than it looks, my photo doesn't do it justice.
If I can't use the cut-off saw, the next option is a 5 inch and a 9 inch angle grinder.
For the holes in the hooks I used a plain old drill press with drill bits and an annular cutter.
To clean up rough edges it's a flap disc on the small grinder or a linishing belt that I made to fit a bench grinder a few years ago.
Nothing too fancy, but it works.
Hugo Habicht
G1900
Jun 24, 2024
1,437
2,017
Ireland
Hello Paul,
now this is really impressive!
I used one of those metal cutting blades in a friends place, years ago, but I only cut box sections with about 2.5mm wall thickness. Never dawned to me that it would handle 25mm solid bar. Have to get one of those. Is it a normal chop saw otherwise? The one my friend used looked like it. What speed is the blade running at?
With an angle grinder it would take ages...
Kind regards,
Paul Allwood
Jul 8, 2025
453
699
Hello Paul,
Kind regards,
The no load speed is 1500 rpm. If by "normal chop saw" you mean the cheap abrasive disc saws, it's similar but the base and vice is a little better.
I use the thin 1.9 mm cut-off discs in the angle grinder, so it cuts pretty fast too, but not normally as accurate as the cut-off saw.
Hugo Habicht
G1900
Jun 24, 2024
1,437
2,017
Ireland
Thank you very much, Paul !
I have a saw which should work, with the correct speed. Is the blade you use from Bosch or another manufacturer?
Paul Allwood
Jul 8, 2025
453
699
I've only used the Bosch blades - there may be others that will also work well but I haven't tried them. Normal price locally for the Bosch blades is about AUD290. I saw them a few days ago on Amazon for AUD127 each so I ordered 2.
2,785
For your angle grinder, I have seen some people that rigidly mount the grinder in a wooden fixture and use it sort of like a table saw with depth guides and angle guides screwed to the deck of the fixture. Sort of a router table but with an angle grinder blade being vertical. I would recommend using some thick “plexiglass“ as a shield between the blade and your body.
10,489
I have both of these and they work incredibly well!
Low speed and fast clean cuts.
Evolution saw:
Multiple blade options:
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
125
114
Lopez Island, WA
I have one of the small 4"x6" horizontal/vertical metal cutting bandsaws... I've sliced 3" round HRS w/o an issue. They're cheap to run, but not as fast as the carbide saws.
11,307
Evolution saw:
I bought a DeWalt version of the Evolution chop saw many years ago (probably 15+ years ago) and long before Evolution was a thing and I've made thousands of cuts with it and gone through at least four blades. Today, I'd buy an Evolution since the DeWalt "table" is a pile of junk. The rest of the saw works great but I really need to fabricate a better table for it, one that keeps the work perpendicular to the blade. Also, I'm running steet cutting blades on my DeWalt worm drive circular saw which work great, but aluminum guides/fences don't like steel chips!
Short version, an Evolution circular saw is in my future for sure, along with a plasma cutting table.
11,307
Y’all won’t be sorry.
It makes life a LOT easier/faster/funner (y) (y)
Preaching to the choir! 😂
I'm going to want a set up that runs plasma and gas. I'm interested in cutting steel plate that's 1" thick or more and gas is the way to go for that sort of thing.
jdfog2
BX2380, loader, mower, tiller, and grader/scraper
Apr 18, 2026
West Central Indiana
After fighting to connect the ballast box to the 3 point a few times, and after reading some posts from others on here about their use of quick hitches, I decided I needed a quick hitch. Since I enjoy getting out in the shed and making stuff I made this too to standard Cat 1 dimensions. Standard here means about the average of the dimensions I could find online for purchased ones.
I had to move the lower pins on my homemade ballast box, and may need to modify the second hand rotary hoe that I haven't used yet, but thought standardizing things to suit a Cat 1 quick hitch wouldn't hurt.
So far it seems to work and I'm pretty happy with how it turned
out.
Ready to connect
Ready to disconnect
The insides
Connected to the 3 point
First test
Seems ok.
Beautiful work Sir! Not everyone has the gumption to even try to fab that up. (Me = Everyone) LOL
JD
