3 point quick hitch
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
692
1,239
After fighting to connect the ballast box to the 3 point a few times, and after reading some posts from others on here about their use of quick hitches, I decided I needed a quick hitch. Since I enjoy getting out in the shed and making stuff I made this too to standard Cat 1 dimensions. Standard here means about the average of the dimensions I could find online for purchased ones.
I had to move the lower pins on my homemade ballast box, and may need to modify the second hand rotary hoe that I haven't used yet, but thought standardizing things to suit a Cat 1 quick hitch wouldn't hurt.
So far it seems to work and I'm pretty happy with how it turned
out.
Ready to connect
Ready to disconnect
The insides
Connected to the 3 point
First test
Seems ok.
Reactions: 22 users
11,757
I look at your QH and I can see the amount of work that went into it. Better built than much of the stuff on ebay and such for sure. You might have got a little carried away with a drill when you made the top hook adjustment brackets though. 😂
Paul Allwood
Jul 8, 2025
692
1,239
Thanks. Maybe I did, but I figured it would be much easier to drill the holes now rather than wish I had later. If I never use them all it won't really matter.
11,757
Out of interest, did you buy or make that top hook?
Donystoy
Dec 10, 2013
735
378
Binbrook, Ontario
Great job! When are you starting on the backhoe?
Paul Allwood
Jul 8, 2025
692
1,239
I made it from 25 mm mild steel using a drill press and a Bosch steel cut-off saw.
It was mostly your posts about quick hitches that got me interested in them enough to think I needed to try to build one, so thank you for your posts.
GrumpyFarmer
5,201
I have two words for you sir:
outstanding
craftsmanship
11,757
Nice work on that hook. It's a bit deep I think but you can always cut it down if it turns out to be a problem.
I'm a QH fan for sure but never built my own! I have a QH10, QH15 and QH20 and used to have a QH05 and for the most part they remain on the tractors. If you combine them with top-n-tilt they're unbeatable. I have used to use two magnetic bubble levels on them in order to know if the box blade is level and plumb, but recently noticed a level in my toolbox that made me think ... duh! 😂 You can see it bungie strapped to the QH20.
GrumpyFarmer
5,201
Thanks, it's appreciated.
NP…I really value craftsmanship and creativity as it’s easy for anyone to throw stones.
When someone crafts a solution for their application (solves a problem), that’s great and I appreciate these type of threads. It doesn’t take much talent (beyond spec and negotiate) to buy a solution. Craftsman creates a solution!
Paul Allwood
Jul 8, 2025
692
1,239
Good point on the top hook. I've never used one so no idea what really works, but as you say, I can modify it if it becomes a problem.
A hydraulic top link is something I may add at some stage.
I like your idea on the level too.
For now, the next things on the list are hydraulic steering, a single tine ripper, then back to modifying the FEL to fix the dump over-travel and change it to mechanical self leveling, finish the bucket, make a bit on tooth bar for it. Not sure what order I'll do these....probably the easiest first, the ripper.
