3 point quick hitch
gbaker53
Kubota B2401DT&FEL RockRake, Rear Blade, Cultipacker, SeedRake, Driveway drag,
Mar 28, 2025
153
116
NC
After fighting to connect the ballast box to the 3 point a few times, and after reading some posts from others on here about their use of quick hitches, I decided I needed a quick hitch. Since I enjoy getting out in the shed and making stuff I made this too to standard Cat 1 dimensions. Standard here means about the average of the dimensions I could find online for purchased ones.
I had to move the lower pins on my homemade ballast box, and may need to modify the second hand rotary hoe that I haven't used yet, but thought standardizing things to suit a Cat 1 quick hitch wouldn't hurt.
So far it seems to work and I'm pretty happy with how it turned
out.
Ready to connect
Ready to disconnect
The insides
Connected to the 3 point
First test
Seems ok.
Very nice work. I have not been welding for very long and it has been a couple of years probably longer since I have done any welding. I would love to be able to weld with your expertise, but I’m just going to have to get to work at it. I only have two cheap HF welding machines, a stick and a line feed. I really need to get a real welder and learn how to use it!
But again very nice job!
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
670
1,179
Baranduda, Victoria, Australia
Thank you. There are tons of welding instructional videos on YouTube. Some that I've found really helpful are a series called TimWelds.
