My genset also has a ground 'lug' that can be used to attach the frame to a grounding rod (driven 5' into the ground). This helps provide a low resistance path to ground in the event of 'stray voltage'. And that is how I used it when powering my house panel.....prior to getting a whole house stand by generator.I'm resurrecting my own thread from a year ago.
One thing I've learned about is Bonded Neutral versus Floating Neutral Generators.
Maybe it's not a common issue, looks like it can be an issue if both the Generator and the connection are bonded when connected as a "whole house" feed?
Two bonds can make for some unexpected charges/electrocution from the generator itself?
Sounds like a Floating Neutral is the preferred?
EDIT - a while back on this thread @Flintknapper was kind enough to post a photo of his generator.
I now notice it's labelled as "Neutral Bonded to the Frame." Not sure if good or bad.
But yes, it is important to understand the difference in a Bonded Neutral and Floating Neutral. When and where each is most appropriate and some of the caveats.
Bonded Neutral vs Floating Neutral in Generator | When to Use Them?
We use portable generators at homes, shops, construction or job sites, camping, and many other places. Most portable generators are plug-and-play type devices i.e., you supply fuel, turn on the generator, plug the appliance and use the power. It is very simple. Depending on where you use the...
www.electronicshub.org
