Thanks for explaining it. Now itThat plate is connected to the spool. When the spool calls to lower, that plate pushes the rod which pushes the poppet, dumping the cylinder fluid to tank. All other times it floats.
Edit to Add: BTW, when you reattach that plate to the spool, you'll need to watch the orientation of the tang on the other end of the spool.
You can get a free copy of the WSM at KubotaBooks. (They'd appreciate a donation.)Thanks for explaining it. Now it
Makes sense. Is that diagram out for your WSM? I need a better WSM….
What's funny about the WSM version on Kubotabooks.com is that it says it's for a B6200HST and B7200HST, But it doesn't have any info about HST models in it.You can get a free copy of the WSM at KubotaBooks. (They'd appreciate a donation.)
The WSM is divided into three major sections -
• General, general bs
• M Mechanisms, how the parts function
• S Service, how to fix it
The diagram above is from the M pages; sometimes you have to work both sections.
There's an addendum on Kubota Books for the HST. You have to watch out on this one, the 2WD model apparently didn't have position control.What's funny about the WSM version on Kubotabooks.com is that it says it's for a B6200HST and B7200HST, But it doesn't have any info about HST models in it.![]()
I have the real WSM for the B6200HST and B7200HST.
