That plate is connected to the spool. When the spool calls to lower, that plate pushes the rod which pushes the poppet, dumping the cylinder fluid to tank. All other times it floats. View attachment 180662
Edit to Add: BTW, when you reattach that plate to the spool, you'll need to watch the orientation of the tang on the other end of the spool.
