If the cenerline is close to true vertically horrizontal slotted mounting holes in the base and shims should suffice.Thanks. Don't think it will be too hard to modify what I've got so far to allow some adjustment.
You have 4 gallons in the sump and a 4 GPM pump on the tractor. Significant head room there. What size PS pump are you contemplating? i would think pretty smsll.I have some more questions....
Is it better to tap into the existing hydraulics to feed the new steering pump, or better to use a separate reservoir and filter ?
If I keep the systems separate, is a spin on style filter (see below) in the return line to the reservoir a good choice, or is there something better ?
If I buy or make a separate reservoir, is bigger better ? My thinking is that a greater volume of oil and larger reservoir surface area will help with cooling.
Many thanks.
Sorry, I'm not sure what you mean ?Any issues with the I-Beam up and down/side to side?
