Red-dyed diel esel
Denny Smith
Kubota BX2380 with snowblower (2816), front loader (LA344S)
Nov 19, 2025
37
20
Michigan U.P.
Hi y'all. Where's the thinking at regardig using #1 red-dyed diesel (BX2380), with additive for winter use? Is there a consensus from current users? Muchas Gracias mi amigos. :)
3,091
Red dyed is 100% the same as on road ........ just the red dye is the difference.
AND - the red diesel is "off road" diesel - not taxed as gas is for highway use.
In your cold climate - a dose of additive is highly recommended - you pick any you think will keep from gelling.
11,275
There is Zero difference between regular diesel and red dye diesel.
Yes, you want to treat your fuel with a Biocide and cetane booster and antigel for winter use.
Denny Smith
Nov 19, 2025
37
20
Michigan U.P.
Thx all. My only other concern is: I put in the water-vapor fuel filter and new fuel lines. Does the red dye mess with filter to the point that I can't visually tell if I have water (It's K's "L" filter)?
11,275
Nope, still works the same.
lmichael
Kubota G2160
Apr 23, 2021
861
441
Rockford IL area
I would not know where to purchase it. I looked around and even though we're in the middle of farm area in that NW IL/Stateline area distributors that list it only want to deliver to large on site tanks
#40Fan
665
492
My closest distributor said they would bring out a tank for free for them to fill. Might call and ask if yours would do the same.
lmichael
Kubota G2160
Apr 23, 2021
861
441
Rockford IL area
If I used more, it would be worthwhile. But in the course of a whole season of using my machine I think I might use 12 gallons max. Oddly even the little Honda 4514 I used to have would suck down 15-18 gallons of gas and the big Simplicity Sovereign would burn up 20 gallons easily. This diesel sips fuel
5,575
Yep, red diesel, it's the same.....100%
Any of the "big named" anti-gel stuff works pretty good for our MI climate. You probably get a wee bit colder than we do in the mitten though.......
One thing to remember regarding anti-gelling fluids is that there is a difference between the stuff that is used as a "preventative measure" and the "emergency, Oh Sh1t my truck wont start" stuff.
Here is an example of the two. (preventative)
but this is for when/if you get caught with your pants down....(Oh sh1t)
Trash Panda
L2501
Feb 18, 2022
290
272
Wyoming
Pretty handy you shaded those two in the same post.
In my experience, using Howes is a sure fire way to guarantee that you need to use 911 down the line!
JonM
Nov 29, 2024
291
684
wisconsin
yeah i dont use howes. i use powerservice anti gel and keep their 911 on hand for emergency. but i only add in the very begining to make aure i have anti gel active when they switch to winter blend
johnjk
Apr 13, 2017
1,821
2,242
West Mansfield, OH
Here in OH we suspended tax on gas/diesel for 90 days. Makes no sense to allow people to run off-road in their vehicles. Same cost right now anyway. As I see it the goal of letting people run dyed diesel on road was to get around the “diesel shortage”. At least in my area, prices were falling before they even acted. IMHO this strikes me as more of an election stunt than true concern for the consumer.
Spam Bot
Windows Computer
Aug 3, 2024
196
143
Austin, Minnesota/Key West FL
I've run home heating oil in diesel engines for over 25 years and never had a problem. I use Power Service in the white bottle and never have a problem. I have a bottle of 911 that has never been opened, and the last time my diesel had a gelling problem was during the Blizzard of 1978. It would start, but you couldn't go anywhere because the cold would gel the fuel. It was an MB 300D, and MB retrofitted a fuel heater with a steel line wrapped around a steel tube installed in the heater hose.
lmichael
Kubota G2160
Apr 23, 2021
861
441
Rockford IL area
Many years ago early 60s just prior to my entering HS my dad moved us out of Chicago to a nearby burb. We had a new neighbor kind of a strange guy in some ways but overall a great guy. When we moved there he had a 1959 Mercedes Benz 190D. Even though back then diesel was only about .15 a gal he wanted to spend less. So he had a fuel oil tank placed outside his garage with a small oil burning heater inside. But the real reason was he had a spigot on the tank and he's fill up gallon cans for a lawnmower with heating oil, and fuel his little Benz for about a dime a gallon. Made me swear secrecy if I ever saw anyone snooping around his garage.
On really cold nights that little Benz sat outside idling all night long.
Pau7220
Aug 1, 2017
786
280
Clarks Summit, PA
Project Farm hasn’t steered me wrong yet. Anti-gel testing starts at about 12:30.
