Plasma cutting
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
740
1,349
I think any type of dryer will interfere with airflow when added to the input side of a compressor. Probably gonna need an additional dry air feed. On a unit like that I wonder if providing a remote air feed will up the plasma output power because a built in compressor must draw quite a bit of current.
All might be right, I don't really know. I'll try one thing at a time so I have a chance of knowing what makes a difference.
Paul Allwood
Jul 8, 2025
740
1,349
I got back to the plasma cutter today to have another go at some 12mm mild steel. There's now an external compressor connected plus a drier and filter in the air line. I'm also trying contact rather than standoff cutting.
It's far from perfect but I think it's progress.
Desiccant dryer and filter.
Machine settings - maximum current and air pressure.
Ready to cut using magnetic tape for a guide - I saw this in a YouTube video @petestools.
Here's a video of some cutting in progress.
All cut.
The back - pretty messy.
The best sections looked like this.
After cleaning up with the grinder.
The next step is for my wife to fill in the middle with leadlight, them we'll mount it vertically between two old timber sleepers somewhere in our garden.
5,461
All cut.
I have never tried this “contact method”, so I am kind of shooting in the dark.
From the pics of the back, I would try to slow down a bit to see if that cleans it up a bit.
Lots of variables to deal with, but regardless, in my opinion, it still beats the hell out of cutting it manually. (y) (y)
Nice work sir!
Paul Allwood
Jul 8, 2025
740
1,349
Nice work sir!
I was finding that keeping a consistent speed is really hard - if only it could be automated.
Agree, much easier than grinding, and thanks.
Sidekick
Jul 29, 2023
1,269
1,824
N.Y,
Looks good. Same thing I said before building a CNC table. I saw this a while back and wonder how good it would work.
Paul Allwood
Jul 8, 2025
740
1,349
I've watched a couple of videos of these and they look pretty good. I think if I was going to spend that much is probably also build a CNC table too. I haven't really looked at this seriously yet, and I'm most definitely open to suggestions.
Too many projects, too little time
Yooper
3901 LA525
May 31, 2015
1,747
926
NE Wisconsin
You will get better with experience. I found it was not only the sight but also the sound that told me my speed was optimal.
3,115
Perhaps you could mark out your magnetic tape with some consistent distance tick marks. Perhaps 10 to 20 mm would be sufficient. Then set up something to act as a metronome to provide you with constant time measurement (or just use some song that has the correct time and play it in the shop).
Start cutting and use the tick marks and metronome sound to guide your speed for consistency?
When welding something I find that doing a similar thing helps me with the travel speed until I relearn to have the consistent speed.
That looks like a long cut so it would be hard to stay consistent with travel speed on that much length.
For a guide, you might try cutting out the shape in a plywood piece and using that as a template. Of course you would have to have the template offset by some dimension equal to a distance on the cutting head. See this site for an example of “plasma cutter radius guide”. (There seem to be quite a few different shapes available)
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
606
622
Lake Almanor, Ca
Keep that tip pointed straight up and down…it will help blow out the slag. Your pic shows that you are angling it creating a longer cut area and allowing the material to slow down and stick. Up the air flow a bit and try that. It should blow way more material away from your piece.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,208
1,823
Pittsburgh
All cut.
If you have some 6mm scrap plate laying around try those same settings and see what you get.
Paul Allwood
Jul 8, 2025
740
1,349
It's not real fancy, but progress is progress.
The box was all made from scrap. The box was re-cut and welded from the first toolbox I made for the tractor but folded wrong. So far I haven't worked out where to connect the PC.
A circle guide with a magnetic centre.
Yooper
3901 LA525
May 31, 2015
1,747
926
NE Wisconsin
Water table I presume? It would help take some of that fine particulate smoke out of the air.
5,461
Paul Allwood
Jul 8, 2025
740
1,349
Good idea. I like mine.
Don’t forget to add a drain for it.
I made a “dimple die” like the one on the Langmuir Forum, it worked good.
https://forum.langmuirsystems.com/t/bar-sink-drain-dimple-die/22761/597
It’s a simple project, especially for someone of your caliber. (y)
Good idea re adding a drain.
I made a dimple die to form dimples on an extra step I made to help climbing in and out of our Unimog. It was about 5 years ago, so the chances of finding it are slim.
The standard step is the top one. I added the lower one.
Paul Allwood
Jul 8, 2025
740
1,349
Today I finished cutting the support bars and made a frame to sit it on a base that already had wheels from something else I pulled apart. Easier than sitting out on saw horses temporarily every time I want to use it. Next to at a drain as suggested by RWS.
Numbers are obviously more complicated than I thought....the top was supposed to end up level with the bench. Strewth !!
Paul Allwood
Jul 8, 2025
740
1,349
Who said plasma cutters don't work on timber ? It's just a bit smoky and not a real clean cut.
OrangeColoredTractor
2017 L2501 4WD HST
May 10, 2017
75
22
Washington
I have a Hyperthem Powermax 1000 G3 and it slices through 1" steel like butter, slower speed, 1/2" and under, I can blow thought it like Darth Vaders light saber. Sure makes you want to throw rocks at the oxy acet set up, but they have their place too.
Having the power of the sun at your finger tips is awesome. I have those stainless templates for cutting circles, squares, trailer light holes including those oval truck lights.
Nice narrow kerf, with a straight edge, little cleanup grinding and no pre heating metal before cutting, stone cold, you are in and out. 1/4" steel, after I cut it with plasma, I can pick up up bare handed in about 10 minutes, oxy acet cut, 3rd degree burns.
What a great time to be alive, all this cool technology.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,208
1,823
Pittsburgh
Input voltage?
Supply gas?
