Hydraulic Issue
Kubotadad
B1550
Jan 31, 2026
Ontario, Canada
3-point hitch is down
Both spools seem the same when activated...goes in and returns, however, the loader spool does not feel like there is any pressure behind it when activated. Feels loosey goosey!
Kubotadad
B1550
Jan 31, 2026
Ontario, Canada
Should I change the hydraulic fluid and pull the strainer? Could it be that simple?
Do I need to drain the fluid before disconnecting hoses?
6,600
Dan - see pics
Neutral Position
Activated Position (it does somewhat appear that the loader spool is not going in as far as the bucket spool)
Retracted Position
Well its moving which was my main concern. There should be two positions when you move the lever to lower. Can you push it into the second posution? It takes a little force to get past the detent.
10,316
Dan - see pics
Neutral Position
Retracted Position
Either your pictures are wrong or something is a foul with your linkage, as 2 pictures are the same spool position.
And if your only moving one spool the other is moving too. :unsure:
Kubotadad
B1550
Jan 31, 2026
Ontario, Canada
Back at it again...A local tractor guy told me to remove the spool end cap and that it is likely the set screw that has backed off loose (said I would need an allen key to tighten). I have removed the end cap and can see the spring...but not sure where the set screw is located? Is there a service/parts manual that shows how to disassemble?
6,600
Put it back together before you break something. Have you determined the spool is or is not moving the proper amount?
6,600
Yes...I have determined that the spool is actuating in and out and appears to be the proper amount...goes in as far as allowable.
Then there is absolutely no reason to have that cap off. Put it back on and turn your attention to checking flow into and out of the valve.
6,600
3-point hitch is fully down
Place the loader on the ground.
Disconnect both lift cylinder hoses at the hard line fittings. Make surd to put identifying labels on both hoses and pipes so you can put them back correctly.
Place the ends of both hoses in a clean bucket
Start the tractor and move the joystick to the lower position.
Do you get oil flow from one but not both hoses? Can you push the joystick further in the down direction and does flow stop?
