Hydraulic Issue
Kubotadad
B1550
Jan 31, 2026
10
Ontario, Canada
3-point hitch is down
Both spools seem the same when activated...goes in and returns, however, the loader spool does not feel like there is any pressure behind it when activated. Feels loosey goosey!
6,376
Dan - see pics
Neutral Position
Activated Position (it does somewhat appear that the loader spool is not going in as far as the bucket spool)
Retracted Position
Well its moving which was my main concern. There should be two positions when you move the lever to lower. Can you push it into the second posution? It takes a little force to get past the detent.
10,061
Dan - see pics
Neutral Position
Retracted Position
Either your pictures are wrong or something is a foul with your linkage, as 2 pictures are the same spool position.
And if your only moving one spool the other is moving too. :unsure:
