B7200 4WD front hub repair
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
653
1,123
Having spent nearly 50 years in a machine shop I've done several repairs like that. We called it "staking" it.
I don't recall any of them failing but some may have and never heard about it. I have even seen original equipment manufacturers use that method in some instances. Most recently in Okuma CNC lathes. In your instance the challenge is going to be working around the other repair and the limited space for drilling and tapping. I would agree the best is to replace but I believe a working fix is possible.
Thanks - all good to know. I agree I've got a bit of a challenge due to the damage that's already been done.
3,053
Paul Allwood
Jul 8, 2025
653
1,123
Paul Allwood
Jul 8, 2025
653
1,123
I've contacted Daryl from Mossy Creek Outdoors (very helpful - thanks NIW and RK for the suggestion) and he has the parts I need - just sorting out postage cost for these and some hydraulic steering parts as well (that'll be another post).
It's a good thing, as I had a closer look at the large bevel gear and the shaft this afternoon, and in metric units they are both harder than a cat's head. The file skated across them and there's no way I'm drilling it with a standard drill bit, and not a chance of tapping to use grub screws as scotch keys. Maybe I could sharpen a carbide masonry drill bit, but.....
Since I've hopefully got parts on the way soon, I'll replace the leaking seal and put it back together with new dowel pins to take out some of the play and get back to using it.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,175
1,777
Pittsburgh
:ROFLMAO:
Stealing that one to use on my dad. He has a bag full of those quips from the coal mine.
For comparison, I would've used the metric "harder than a nun's heart".
Paul Allwood
Jul 8, 2025
653
1,123
I reassembled the right front hub with new dowel pins into the holes that someone had previously machined to overcome the stripped spline. After trying to re-drill the holes and finding out how hard these parts are I decided that whoever fixed this previously actually hasn't done too bad of a job. Also fitted a shim that I turned from a hard washer to take out the end play. Same as the left, this side also got six new wheel studs made out of class 8.8 bolts.
Re-filled the oil, put the wheel on and tested - all good.
This is still only a temporary fix until the parts arrive from Mossy Creek Outdoors, then it will get a permanent fix.
PXL_20260201_042911813~2.jpg PXL_20260201_042858032~2.jpg PXL_20260201_041743263.MP~2.jpg PXL_20260219_000356446.MP~2.jpg PXL_20260219_025352763.MP~2.jpg
Reactions: 7 users
3,652
2,071
:ROFLMAO:
I have been known to use "Tougher than boiled owl" quite often
Paul Allwood
Jul 8, 2025
653
1,123
The second hand bevel gear (looks new), the stub axle and the half round retaining bits arrived from Mossy Creek Outdoors this afternoon. The splines fit together beautifully with almost no play.
Hopefully I'll get these fitted to the front right in the next few days to replace the temporary fix that I found in there recently.
Paul Allwood
Jul 8, 2025
653
1,123
Out with the old (front right bevel gear and stub axle)....
Assembled the "new" bits with the replacement bevel gear and stub axle from @Mountainman Mossy Creek Outdoors....
I wasn't able to push the end of the stub axle shaft into the inner bearing by hand on this one....
So I removed the inner bearing which was an easy tap in fit in the housing....
And pressed it onto the shaft....
Then it all went together nicely. All spins freely with no play and no unexpected noises.
Took it for a 5 minute test run - all good.
Back to the shed to pack up and I as was tipping the drained oil into a waste oil drum I remembered that I HADN'T RE-FILLED THE HUB WITH NEW OIL. Lucky I didn't decide to keep going on the test run and mow the grass today. It could have been an expensive mistake.
Reactions: 8 users
Paul Allwood
Jul 8, 2025
653
1,123
What started out as a simple project to try to fix the runout of the left front wheel, ended in a slightly bigger job (pretty standard). Not only is the left front wheel now running true, but the front right front hub has some "new" bits fitted to fix a problem that I didn't know I had.
Next - new wheels and tyres, hydraulic steering and fixing the FEL geometry.
Reactions: 6 users
Paul Allwood
Jul 8, 2025
653
1,123
@North Idaho Wolfman Can the title of this thread be changed ? The current title probably won't be very useful in future searches - something like B7200 4WD front hub repair might be better.
I can't work out how to change it.
Hugo Habicht
G1900
Jun 24, 2024
1,540
2,230
Ireland
Go to post #1 and select "Edit".
You should be able to edit the thread title then.
