Do tire chains help much on sub compact tractors?
MAXA
B2650, B7800
Jan 12, 2025
72
NJ
We got snow and i am sliding all over the place with loaded tires do tire chains make a huge difference in sub compact tractors? B2650.
If so can anyone suggest what type of chains i should buy and where to buy them? I don't know if tractor supply would have them in store. They are costly and look like a pain to put on. :)
My tires are R4 12.4 - 16
Also should i buy Chain Tensioners?
Thanks for the input.
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
279
234
Wahkiacus, Washington
Chains of the B7100 AND on Big Berta AND they never come off. Tensioners are heavy tarp straps after I get them cinched as tight as possible. GOOD quality chains are indeed expensive. But only once have I had a cross bar break.
But we don't have any hard surface to scratch up. Lastly, I don't ever have to find them ever again in 2' of snow ;).
Shawn T. W
Dec 9, 2024
777
1,408
SW Missouri Ozarks
Yes, they make a HUGE difference!
Are you having trouble moving, or steering?
Yes, they are expensive!
Or cheaper
Cheaper yet, but not nearly as good, the cross links like to slip down between the lugs of the tire ... https://www.tirechainsrus.com/produ...thickness=10mm&attribute_pa_full-size=12-4-16
Either tensioners or rubber bungees ...
JRHill
Apr 26, 2016
279
234
My big girl has cross links - and one of 'em broke years ago. The toy tractor has cross bars but not all of them fall into the lugs. If it was more of a problem I'd have cross bars on both. Thank the Lord both have rear diff locks and I use the lever or floor push button before I need to. It's a pat your head while rubbing your tummy thing x 2 or 3 though.
MAXA
B2650, B7800
Jan 12, 2025
72
NJ
Both and i have 500lbs on the back.
The Trygg Fast Trac Tractor Tire Chains look mean! I would be on gravel.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,934
2,332
Western MT
Chains make a big difference. Do tension the chains. Even regular bungies will work.
Fwiw, I just have ladder chains and they work, too. I got mine at https://tirechain.com
MAXA
B2650, B7800
Jan 12, 2025
72
NJ
Do you guys think i would need wheel spacers before they would fit?
jimh406
Jan 29, 2021
2,934
2,332
Western MT
I have the OEM spacers on my L2501. I don't know if I needed them or not. If you can handle putting the spacers on, I'd probably buy them. They add stability.
But, you could try the chains without them. You don't need that much clearance for rear chains. You can look on the inside and see what you have now. More space will make it easier to put the chains on though.
Someone with a B2650 will probably chime in.
6,275
I used my riding snowblower(SSCUT ) today.5-6 hours seat time, yeah my butt Hurts !. Generic 'tire chains'' for a rider, bungee corded to keep them tight to tires. Had ZERO traction problems dealing with the 2' of snow from overnight, so YES, chains make a HUGE difference !
SDT
Apr 15, 2018
3,674
1,402
Tire chains make a huge
Tire chains make a huge difference in snow and, especially, ice, much, much, much more improvement than any added ballast.
Go to the tirechains.com website and read the information regarding types of available chains. You will find more information than you will ever need.
Tractor supply, etc., will not have tirechains in stock. Order yours from tirechains.com after doinig your homework.
You will need wheel spacers if your 2650 is a cab version but not if open station.
If you take the time to properly fit your chains (I know of no one aside from myself who actually does this) and install them properly, they will not move and tensioners will not be needed.
SDT
Apr 15, 2018
3,674
1,402
Only if your 2650 is
Only if your 2650 is a cab version.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,175
1,777
Pittsburgh
I'm not too wild about running tire chains upon my manicured lawn.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
I've been running grooved tires on the last two tractors and that's been enough for traction. My first tractor here was a 2WD Cub 154 LoBoy with old diamond pattern turfs on the rear. It would not move in the snow without chains. With chains it went like it had 4WD.
MAXA
B2650, B7800
Jan 12, 2025
72
NJ
Can anyone out there with a B2650 ROPS confirm that you do not need wheel spacers to run chains? My tires are goodyear sure grip lug 12.4 - 16.
I also use a mid mount mower which appears to not work if you use wheel spacers.
Bee-Positive
Nov 16, 2022
970
926
Amsterdam, NY
MUST HAVE CHIANS. At least for my situation, I have the smallest compact, BX1880.
Got them at chains dot com
I have turf tires and they are great in snow - but - I loose steering when pushing full loads of snow.
your tires may be a bit bigger diameter so clearance may be tight.
SDT
Apr 15, 2018
3,674
1,402
I once owned a B3350 ROPS model. The 3350 is very similar to the 2650 aside from the engine.
I used tire chains on the 3350 without wheel spacers before I added wheel spacers for other reasons. Yes, there is adequate clearance but just enouth and you will need to install the chains tightly as should be done in any case.
I also had a 72" MMM that I could mount with or without wheel spacers.
FWIW, the Kubota wheel spacers that I had are 1 3/8" wide. There is a reason for this, and all bets regarding MMMs are off if one goes wider with wheel spacers and/or optional, oversized tires, which cannot be used with chains, cab or ROPS.
