Differential lock broken pins?
Rosohatica
Kubota L3200, Tehnos MULS 130 flail mower, Fužinar 14” plow, Landforce 5′ tiller
Feb 23, 2022
234
106
Zagreb, Croatia
Hi all,
Some of you may have read my earlier post about working in very muddy conditions. If not, it’s here for context:
https://www.orangetractortalks.com/...o-to-or-on-your-kubota-today.6326/post-823323
Today I tried to engage the differential lock, and the pedal goes down very easily with almost no resistance. That immediately raised a concern, so I reviewed the correct operating procedure for the diff lock. Unfortunately, I realized that on that muddy day I engaged it completely against recommendations—while the wheels were already spinning, likely with one wheel spinning freely in the mud while the other was not.
Based on what I’ve since read, engaging the differential lock under those conditions can cause the differential lock pins (or dogs) to break, which would explain the lack of resistance at the pedal. I’ve also found that this type of failure seems relatively common on the BX series, with several videos documenting it, for example:
From what I can tell, the BX differential uses four pins. My questions are:
  • How many differential lock pins does the L series use (specifically the L3200)?
  • How common is this type of failure on the L series ?
  • What is the easiest or least invasive way to confirm whether the pins are broken?
  • If this is indeed the case, should I stop operating the tractor entirely until it is repaired?
Thanks in advance for any insight.
JasonW
798
555
Al
It could be the return spring for the lever.
Does the diff lock still work?
I don’t think the pins are as fragile as some say they are, I’ve seen some rough operators engage the lever with one wheel spinning and the other stopped, but no damage occurred.
The wheels spinnings isn’t an issue it’s if there is a difference in speed between the two wheels is where it can cause damage.
6,575
How many pins? Based on the parts diagram at Messick’s looks like 8? Kind of hard to tell the way it’s oriented in the diagram, but more than 4.
How frequent do they fail on L’s? No clue. I know the first time I used mine, I was acting before thinking instead of thinking before acting, so didn’t do it anywhere near right. Almost immediately thought “probably just shredded the diff lock”. It’s still fine.
Easiest/least invasive way to check? Try it and see if it works. Find another mud hole. Jack up one side just enough to get one wheel barely off the ground. Find some wet grass you don’t mind tearing up, lock the diff, and make a sharp turn. Probably many other options to test its function.
Should you continue to operate if the pins are sheared? Others likely have more expertise on that question. I wouldn’t be very comfortable with substantial chunks of metal rattling around in a box full of gears.
7,202
Its easy to check the lock. DIsengage MFWD, put the loader up against a big tree, engage the lock, and spin the rears. It wont tell you if ALL the pins are intact but personally I am not going to tear it apart because I thin pleasek I MIGHT have damaged one. I did have the lock on my B7200 wear out and stop working. It used a solid dog clutch rather than "shear pins". :devilish:
10,980
The Diff lock on a L3200 is much better than the lock on a BX.
There is 8 pins that engage the diff lock.
It's not very likely that you sheared all 8 pins.
Also these L's don't make it very easy to engage when the wheels are spinning.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
Thanks for the info. I just came to the tractor so went to check how it behaves. It seems that differential is locked without me pressing the lever. I just tried to go backwards on the muddy slope and the tractor was stuck in the spot with both rear wheels equally spinning. At the same time, engaging lever was up and it can be pressed down easily but the spring returns it back up if I don't hold it down. My take on it is that pins are broken and stock in a locked position. Can you confirm this theory or I should test something else?
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
I just did another test - lifted one rear wheel of the tractor off the ground using a jack. Another side remained firmly on the ground. I tried to spin lifted wheel using hands, but it is stuck - it doesn't move.
10,980
The diff lock is stuck.
It's not very likely that the pins are broken, as broken pins would prevent it from locking.
Check this linkage (green) bet it's off.
The other possibility is that it's lost its connection in yellow, that will require you to remove some parts to get to it.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
What do you mean by green linkage being off?
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
3,055
I am not 100% sure how your mechanism works. It appears that it only rotates the differential engagement fork and that forces a ramp down into the lock and moves it inwards to engage. On my older tractor there is a mechanism that actually moves the rod inwards and outwards.
But it looks like you are going to have to remove the seat and the upper case cover (where the three point cylinder is) to see what is not working on yours. That will give you some visual access to see what is going on inside the case. You might be able to get some sort of boroscope camera into the case and see??
I imagine that upper cover is pretty heavy, so be careful. I don’t see any removable covers in the diagram but look around for some access to be sure. I imagine that cover is attached with a ThreeBond RTV type gasket maker so that will act as a glue also.
utterchaos
L245DT FEL l39 TLB
Mar 17, 2023
24
9
Chenango, NY
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
There’s only a very brief glimpse of the roll pin and it looks like it may have worked out past the inner rod and possibly isn’t doing anything to make a connection and release the lock when in the return position.
Worth a look to make sure the inside rod is turning with the outer sleeve.
Thanks for the hint. Indeed, I missed that detail. I will take a look as soon as I get to the tractor. Meanwhile I tried to search for the dimensions of the pin. Attached find an image. It looks like it is rather long. I guess it is around 1.375 inches and I assume shaft rod is around 0.5 inches which means pin would be sticking out on each side.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
So is opening top lid just for inspection or the problem can be fixed from above, without opening side part shown in the image below?
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
Diff lock is stuck in locked position. Yes, I used it in situation where one wheel was spinning fast in the mud and another was still.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
Thanks for your thoughts. I wrote above some of my new findings.
10,980
You will need to do a tear down if it's damaged, the top cover will only let you see it.
Depending on the damage you might need to get into both sides, but you would start by getting to it on the left side housing.
