WI_Hedgehog
Apr 24, 2024
984
1,374
Milwaukee, Wisconsin, U.S.A.
Brilliant picture !
Reminds me of some creature from a horror movie, with glowing eyes and huge claws :giggle:
That you can move this size rocks with your tractor is most impesssive (y)
Thank you.
It is beyond the tractor's rated capacity, that is perhaps 1/12 of the rock that must be moved to drill a new well. The front right tire was displeased, and I drove very slowly and carefully.
To start with I split the rock into quarters (with some unfortunate fractures), this is the far side:
Then split each 1/4 of the near side into halves, so each piece is 1/8 of the rock...or more like 1/10 due to fractures on the far side:
After removing the top pieces, (the parts on the right are from fractures during the initial quartering)
I split the near side bottom in halves:
The front left part is the piece in the original picture I posted, most of it was underground, which is the brown part on the left in the following picture taken when pulling it out, the grapple grabbing the top part:
That piece was, uh, deceptively big.
Reactions: 10 users
Shawn T. W
Dec 9, 2024
477
871
SW Missouri Ozarks
It's impressive! I seen videos of folks moving heavy stuff with th sub compacts with no rear tires touching the ground. Crazy.
Unfortunately the whole weight of the tractor and load is then on the poor front axle ... A good way to be getting fresh new seals at a very minimum ... :oops:
nerwin
Nov 13, 2024
602
1,611
Vermont
youtube.com
Yup, especially if you do it often. That's why I kinda like my L2501. That front axle is massive, gives me a little bit of piece of mind. Not that I lift up things that are too heavy. I haven't seen my front tires depressed yet.
lynnmor
B2601-1
May 3, 2021
1,691
1,487
Red Lion
Thank you.
This might have been a good job for DEXPAN
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,924
2,364
Near Lancaster, PA, USA
Yes, I have thought about it. But, I have hardly enough room to get a very looong skinny funnel into the fill opening let alone a vac hook up. Also the filters are right a the bottom with 10 gallons sitting above - seems like a partial vacuum and two filters might be a reach ?? But that is just a feel. My method is easy enough so I haven't felt the desire to try.
gg
Without seeing the filler, can't say much except maybe a 90° fitting would help? No need to remove two filters together and challenge the vacuum's capability. Just replace one at a time. I've used the vacuum method and would bet I lost less fluid with that method.
WI_Hedgehog
Apr 24, 2024
984
1,374
I looked into DEXPAN (from another post here I think), it creates about 18,000 pounds of force per hole. Wedges are good for 15,000# with a 3# hammer, 20K with a bigger hammer--but the wedge gets damaged from any bad hit. The benefit of wedges is controlling the sheer line by feel, which, once you get the feel for it, is quick and pretty easy, and requires far fewer wedges and therefore fewer holes than DEXPAN, and therefore less time and cost.
Before:
(left)
(right)
(near)
(near, with wedges)
After:
Mind you only 1/3 to maybe if I'm lucky 1/2 of the rock is visible.
The trick is to not bang wedges like in tree work, but to tap and listen to each wedge, then tap the wedges that you want to steer the sheer line with once, then tap a neighbor once, and continue the process like that.
Exactly. But once it was pulled out it was a little late, only 1/3 that weight was expected.
I love your videos, and your tractor.
Hugo Habicht
G1900
Jun 24, 2024
1,064
1,547
Ireland
The trick is to not bang wedges like in tree work, but to tap and listen to each wedge, then tap the wedges that you want to steer the sheet line with once, then tap a neighbor once, and continue the process like that.
Unreal!
And the size of this rock!
How long did it take you to dig it out, split it into pieces and move it with the tractor?
g_man
Feb 3, 2023
321
1,455
NE Vermont
The filler plug is that reddish smudge below and behind the rear remote QD's and valve and hose.
With two guys telling me I should try it then maybe I should. How tight of a connection to you need on the vac hose ??
gg
nerwin
Nov 13, 2024
602
1,611
Vermont
youtube.com
Before:
(left)
(right)
(near)
(near, with wedges)
After:
I'm impressed what the BX tractors can do. I thought they were equivalent size of the 1023/25R tractors from John Deere but I didn't know they were actually bigger. The BX machines are even smaller which is even more impressive.
lynnmor
B2601-1
May 3, 2021
1,691
1,487
Red Lion
gg
I don't like a tight fit and let a fair amount of air to leak into the vacuum. If you pull a high vacuum debris can be pulled in past seals and past the loosened filter.
WI_Hedgehog
Apr 24, 2024
984
1,374
Unreal!
Still working on it, 3 weekends splitting and moving so far. It would take less if I knew what I was doing, but it's "learn as you go." I watched a guy on YouTube split a rock the size of his foot with three wedges, I thought, "I just need more wedges."
mdhughes
L3901DT
Dec 10, 2014
1,395
1,256
Ste Geneveive county, MO
gg
The L3901Dt has 7.5 gal and the shop-vac was able to hold it back.
Do you have a cab tractor that it is hard to get a funnel into the fill opening?
nerwin
Nov 13, 2024
602
1,611
Vermont
youtube.com
I assume you're discussing changing hydraulic filters? I changed mine using the shop vac method. It worked great, hardly lost any fluid. Although the shop vac did suck up some 🤭
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
41
247
MN
I was afraid of my shop-vac sucking fluid when I did my 50 hr service. Did it the old fashioned way, remove and quick spin new filter on. Only lost about a quart, then I asked myself, did the new filter come with a magnet like the old one?
So instead of asking or researching, I gently removed the new filter, saw a magnet and spun it right back on. Causing me to lose another 1-2 qts of fluid. All in all I used almost a gallon of UDT2 fluid. o_O
Today after riding with a couple friends, I prepped the track for the next weekend ride. Season is coming to an end, so days like these I'm grateful.
nerwin
Nov 13, 2024
602
1,611
Vermont
youtube.com
When I said it sucked fluid, not like it sucked much 🤣 just a tiny amount. Still better than losing a gallon! I think I lost half a quart.
MotoBBQ
Jun 26, 2023
41
247
MN
Had I been wiser, I would have only lost one quart. The price was peace of mind for me.
That said, I'll try the shop-vac method next time at my 200 hr service. :)
