1984 L345DT Refurbishment
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
You will need to decide how many valves you want, probably two minimum and possibly three or more. You will need to figure out how to mount the valve, probably on the ROPS if you have one. I would not pursue an old valve.
Then you will need to get the cylinders to fit your tractor. For these I recommend you get Fit Rite Hydraulics to make them. In fact, that is who I brought the whole system from (valve, mount and cylinders)
Then you will need a few new hoses probably.
I'm working on sourcing the ROPS. Can you share any information on the type of valve I'll need? I don't think sourcing hoses will be a problem - I have a lot of oilfield and equipment vendors nearby in ETX as well as my local dealer.
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
It is interesting that the yellow color is NOT listed in the chart linked above.
I would use OSHA safety yellow just because it is easy to get.
Went by my local dealer today to pick up another can of "old" orange. They have a restored 80's vintage tractor in their showroom and I snapped a photo of the yellow pedals.
I've got to say, I don't like the yellow on the throttle lever and foot actuator. Has anyone else seen this on other similar vintage tractors or is this just something they decided to do?
The guys at the parts counter were stumped when I asked them about the "kubota yellow". After talking to the guys in the shop they suggested using safety yellow from tractor supply, but I'm not sure it will be mustard enough. So grateful to have first world problems!
3,150
See this valve that is something like you would need. You need the power beyond sleeve also. There is a good diagram lower in the post showing the general arrangement for the hydraulic circuit.
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
Am trying to remove the left side brake pedal. Both are on the right side.
Specifically, i need help understanding what tool and procedure I should use to remove the pin that goes through the rod.
My .pdf service manual is truncated after the wiring diagram and so doesn't include the section on brake pedal removal.
Any help? Thanks!
Close up of pin.
3,962
2,460
Any help? Thanks!
Close up of pin.
Looks like a roll or spring pin. Need a hammer and punch just small enough to go in the hole and drive it out. I like to back up the back side with anvil, pipe, etc.
3,150
I agree that is a roll pin or spring pin as Kubota calls it.
They make tools to push them out and you can probably make one yourself. They also sell sets of punches that are specifically designed to remove roll pins. Search internet for “roll pin removal tool” for examples of the tools.
You should try to get it soaking in your favorite penetrating oil for as long as you can before trying to remove it. They are prone to rusting into the parts and being hard to remove.
You may want to remove that whole pedal assembly that carries the clutch pedal and brake pedals. There are some clamp looking parts on the bottom of the tractor holding it on. It should be pretty easy to get off except for the linkage removal which might be a little tedious.
Good luck with it!
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
Things are coming along...
Before:
After:
I ended up using the Yellow Implement spray-paint from Tractor Supply. I'm not sure it's "mustard" enough, but I'm happy with the result.
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
The right rear fender required only minor touch-ups for my standard of repair. Isn't perfect, but came out looking good.
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
My L345 came without a hood pin. This part is discontinued. Anyone have a source or ideas on how to build a latch to keep the hood from flopping around when I put this thing to use?
Hole where pin secures hood...
7,714
Get a picture of one and get "Runs With Scissors" to make one. He likes weird challenges.
3,150
That part fit 18 models so you might have a good chance of finding one.
There are used parts available for L series at this place in California
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
Like many units of this vintage, the 3' exhaust stack was knocked off the top of the muffler. The previous owner used JB-weld to attempt a fix, but it didn't hold. I put PB-Blaster on the muffler mount bolts for several weeks and they still twisted off with a wrench. I later found out how soft the metal was when drilling out the holes.
This was the state of things yesterday afternoon:
With that much thread still showing, we thought, hey, let's weld a few nuts to the top of those studs and back-em out! Out come the little MIG.
The welds held, but unfortunately the studs didn't. We just twisted off more material.
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
Out came the grinder and the drill. The secret here is to have fresh, sharp drill-bits. We started with an 1/8" pilot hole and worked our way up to 5/16" through 2 more steps.
We shop vacc'ed away metal shavings as we went and used a rag to keep metal shavings from falling down in the manifold.
Now to clean up the muffler and stack and reassemble those!
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
Used a cutoff wheel to remove the top of the muffler and separate all the JB weld from the useful portion.
With the muffler and exhaust stack off the machine and cleaned, I was ready to begin thinking about how to reassemble. A friend owns a nice CNC plasma cutter and made me this handy doughnut to mate the top of the muffler and the base of the exhaust stack.
Before assembly:
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
Here is one of the stock headlights with the bezel removed.
I'm planning to install some sort of aftermarket LED. Sure would be nice to use the stock bezel too. Now off to the inter-webs to find something useful. If you've done this already, like this guy, please post up what LED you used.
7,714
An easy way to clean up that bezel of rust is to make a wad of tin foil like used in the kitchen, then simply rub it back and forth....... rust gone!
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
Removed the inner, reflective liner of the headlight assembly to fit Par36 bulbs in the stock bezel and frame. Came together pretty good!
DSDispatch
L3800, L345DT
Apr 22, 2020
66
38
Longview, TX
Does anyone know what these nuts on the right rear fender of my L345 are supposed to be used for? The Messicks parts diagram shows no attachments on the fender. What goes there?
