M7040 3 point weakens throughout the day
Mikec575
62
11
I have a bucket that has all types of fittings and just hoses laying around but nothing organized.
I can just buy everything new I need for this that way I am not spending timing trying to make stuff work.
7,344
Here is a basic test rig.
Right end goes to pump delivery and left end goes to sump. You hook it in, open the flow control valve to max, and start the tractor. Then slowly close the flow control while watching pressure rise. You dhould get to 2500 PSI with the valve partially open. I can whip one up if you want.
7,344
Yes sir that would be money well spent for me. So I would just need 2 short hoses to hook to the male ends on the tractor
Yes, in this case you can just replace the factory U-tube with the test equipment.
I will get this made up ASAP. Are you OK with male JIC-08 ends?
Mikec575
62
11
Yes sir that’s fine and I can get two short hoses made to fit the nipples on the tractor.
7,344
every time I did them, they were low at the remotes. 500-1200 psi at high idle (usually). Maybe I fixed something else while I had the pcv off/apart?
I dont know what you fixed but the PCV/CSV are on the downstream side of the remotes. A bad CSV can bleed off lift cylinder pressure but it has no way to affect pressure or operation at the remotes.
