Front loader for a B7200
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM
Jul 8, 2025
146
84
G'day all
I'm in the process of building a front loader for my recently acquired B7200 and have a question about pins and bushes.
I've bought some steel bushes with greasable 5/8" pins that are normally used for trailer leaf springs (see pic). In loaders such as the B1630/B1640 would it be normal to use a greasable pin into a steel bush, or is there normally a bronze bush fitted as well to allow for wear and replacement ?
If needed, there's plenty of size in the steel bush that I could bore them out to fit a bronze bush and still have plenty of steel left to weld.
I've also attached some pics of the progress on the loader - so far I have the sub-frame mostly done, roughly copying the sub-frame in the B1640 loader manual.
I'm interested in your thoughts.
Thanks
3,337
1,946
My pins are considerably larger than that, but they are steel on steel. I'm pretty sure that's common on small tractors. I think that's why the lube interval is only 10 hours (plus, they're not sealed).
9,074
You want 1" minimum pins.
(Technically 7/8 but they are harder to find.)
5/8 is way too small.
Steel on steel no bronze bushings.
5,567
The B1630 had zerks on the cylinder eyes and ordinary 3/4" steel pins with a locking tab to orevent them from rotating. There were no servicable bushings - the pins were fit to welded in mild steel tubing. It used commodity welded cross tube loader cylinders with a 1.5" bore.
My advice - its a small lightweight tractor- resist the urge to over build.
3,337
1,946
Do you know what diameter your pins are ?
On the TL720, the pins are nominally 30 mm. Many of them have the zerks recessed in the end of the pin, to protect the fitting I suppose. As @TheOldHokie said, most have bolts through tab retainers. I think this prevents the pin from rotating, limiting wear to the inner part
5,567
The B1630 was minimalistic. Here is a bottom bracket and pin. No bushings. No bolts. Just a 3/4" pin snd welded tab with one edge bent down. No significsnt wear in my 30 year ownership.
Paul Allwood
Jul 8, 2025
146
84
The B1630 had zerks on the cylinder eyes and ordinary 3/4" steel pins with a locking tab to orevent them from rotating. There were no servicable bushings - the pins were fit to welded in mild steel tubing. It used commodity welded cross tube loader cylinders with a 1-3/4 bore.
Thanks Dan
Paul Allwood
Jul 8, 2025
146
84
Thanks Dan - the urge to over-build is always pretty strong.
dano7200
Kubota B7200 4WD
Jul 30, 2025
70
10
Southwest Michigan
Don't know if it's "Kubota Orange", but it's close enough for me.
I think thats a great match Paul. Enjoy the old school light orange too. I use the popsicle orange color they have at TSC. I think it's Krylon. I can't tell the difference on my B7200. Good cheap alternative to the expensive stuff. What color did you use?
Paul Allwood
Jul 8, 2025
146
84
Thanks. I used this....
torch
Jun 10, 2016
2,764
985
Muskoka, Ont.
G'day all
I may be a bit late to the party here, but I used 1" dom tube for the bushings and 1" cold-rolled for the pins. Before cutting the pins to length and machining, I used them to align things before tacking the bushings in place:
Ultimately, the pins were bored a little over half their length to accept a grease nipple then cross-drilled and grooved at the midpoint to distribute the grease outwards. The hole at the end of the pin accepts a bolt, securing it to the bushing at one end.
Works well. Grease oozes out both sides and still no perceptible wear 9 years later.
Paul Allwood
Jul 8, 2025
146
84
Nice job, looks great.
