G'day all
I'm in the process of building a front loader for my recently acquired B7200 and have a question about pins and bushes.
I've bought some steel bushes with greasable 5/8" pins that are normally used for trailer leaf springs (see pic). In loaders such as the B1630/B1640 would it be normal to use a greasable pin into a steel bush, or is there normally a bronze bush fitted as well to allow for wear and replacement ?
If needed, there's plenty of size in the steel bush that I could bore them out to fit a bronze bush and still have plenty of steel left to weld.
I've also attached some pics of the progress on the loader - so far I have the sub-frame mostly done, roughly copying the sub-frame in the B1640 loader manual.
I'm interested in your thoughts.
Thanks
Thanks
