I am pasting what I wrote for my own reference. Seems correct, but then you get what you pay for, so beware.
KUBOTA ZD326 STARTING CIRCUITRY
Some of this material is repetitious because it makes it easier to understand. Wire color codes follow at the end.
OVERVIEW
The starting system's main parts of interest are the ignition switch, ECM (controller), starter relay, starter (includes solenoid), two NO motion lever safety switches, one NO seat safety switch, one NO PTO lever safety switch, and one NC brake safety switch.
N=normally. O=open. C=closed. "Normal" means the mower will not start.
PURPOSE OF ECM
The ECM's only purposes are 1) to monitor the safety switches and either agree or refuse to tell the starter relay to start, and 2) to power the relay that shuts down the mower. When the key is turned to the stop position, the ECM closes the shut-off relay for about 10 seconds, cutting off fuel.
It does not do anything essential, like making the engine run correctly. It can be bypassed completely if necessary. The ECM is not likely to fail, but if everything else has been checked, and the symptoms are consistent with ECM failure, it has to be replaced. It can't be repaired without extraordinary effort.
A failed ECM can cause the mower to refuse to crank or stop. A failed shut-off solenoid can prevent the mower from starting and stopping, but it can't prevent it from cranking.
A bad ground or other connection can simulate ECM failure.
The ECM has 9 connections.
OR = positive from PTO switch
BR = positive to starter relay coil
GB = positive from left motion control lever switch
WL = power to shut-off solenoid.
B = ground
YR = positive from seat switch
RY = positive from ignition switch terminal AC
WB = positive from brake switch
RW = positive to shut-off relay coil
RELATIONSHIP OF IGNITION SWITCH TO ECM
The ignition switch has a rotating conductor (terminal B) which is turned by the key and always hot. It is always connected to the R positive wire. When turned to any position other than off (glow plug, start), it is in contact with terminal AC, which can be considered the ignition's ECM terminal.
Terminal AC is connected to the ECM (controller) and all safety switches (motion lever, seat, PTO, brake). The motion lever switches are in series, so 13 (right) is connected to RY and AC, and 14 (left) is connected to the ECM, providing positive input. The path goes AC-RY-left switch-right switch-ECM.
NORMAL START PROCEDURE
To start, close every switch except the brake switch (levers at rest, PTO off, operator in seat), and open the brake switch by applying the brake. Turn the key partially, letting the glow plug heat if needed. Then turn to the start position and hold until the engine starts.
BYPASSING SWITCHES
The brake safety switch is normally closed (NC). All others are NO. Because it's NC, the brake switch can be bypassed by pulling the connector and covering it. To bypass the other switches, you have to jump them.
HOW IGNITION SWITCH WORKS IN GLOW PLUG POSITION
When the ignition switch is turned partially, it first connects hot terminal B to both terminal AC and terminal 19. Terminal AC feeds the ECM via the RY wire, and terminal 19 runs the glow plug lamp and glow plug.
Terminal 19 is not significant for starting, running, or stopping the mower. Current goes through terminal 19, the lamp and plug, and then to ground. The mower should start and run fine when 19 is out of commission unless the glow plug is needed.
IMPORTANCE OF TERMINAL AC AND RY WIRE TO STARTING
The RY wire that goes from terminal AC to the ECM sends signal through all safety switches along the way. The safety switches all get positive from RY.
IF TERMINAL AC IS BAD OR WIRE RY ISN'T LIVE, THE MOWER WILL NOT START BECAUSE IT WILL ASSUME A MOTION LEVER SWITCH OR THE PTO SWITCH IS IN THE WRONG POSITION.
THE ECM HAS A SINGLE GROUND, AND IF IT FAILS, THE ECM WILL NOT WORK, CAUSING STARTING AND STOPPING PROBLEMS.
HOW IGNITION SWITCH WORKS IN START POSITION
When the ignition switch is turned past the glow plug position, it disconnects 19 and connects hot B to AC and terminal 50 (BY). Terminal 50 feeds voltage through the BY wire to the starter relay. If the relay is closed, the voltage goes out through the BW wire to the starter solenoid. This is the voltage that tells the starter solenoid to turn.
The starter relay is closed by the ECM (not the ignition switch) through the BR wire. The current exits through the relay coil to the B wire (ground). Don't confuse the B (black) wire with the ignition switch B terminal.
To start the mower, the ECM needs to see safety switch positive at YR (seat), OR (PTO), and GB (left motion lever in series with right). It needs to see RY positive next to the brake switch WB input. If it sees positive at the input from the brake switch (WB), the mower will not start. WB should be neither positive nor negative when the mower starts. No input.
STARTER RELAY
The starter relay is #6 in the manual's diagram. It connects to BR (ECM), BY (ignition positive, terminal 50), BW (positive signal to starter), and B (ground) wires. It has 5 connections, one of which is not used. It switches between two poles; off (87A, dead) and on (87, BW). In the rest state, the switch connects the dead pole. Terminal 87 is the BW wire which goes to the starter solenoid.
Terminals 85 (BR) and 86 (B) send ECM juice through the coil. They are connected to the BR (ECM hot output) and B (ground) wires. The B wire is not important for analysis, since it never changes. A positive input has to be connected to BR in order for the relay to close, and the ECM does this. BR exits the ECM next to OR, if the schematic is any indication.
When the relay closes, it connects the relay switch's BY wire (positive input from terminal 50) to the BW wire that feed the starter solenoid. This starts the mower.
On the schematic, from top to bottom, the starter relay connections are:
1. ECM - BR
2. Ignition switch - BY
3. Starter - BW
4. Ground - B
Jumping BY and BW should bypass the ECM and start the mower without harming anything. UPDATE: I tested this, and it works just fine.
The shut-off solenoid can also be set up this way, but you have to put in a timer or a momentary switch, because if the solenoid is always trying to shut off when the key is in the stop position, the battery will drain.
The manual shut-off lever is easily reached at the right rear of the mower.
TESTING RELAYS
All three relays on the mower are the same. You can test resistances to see if they are working. The manual's test resistances are wrong.
Resistances:     85-86: ~90 ohms (coil)
        87-87A: infinite
        87-30: infinite
        30-87A: 0 ohms
REMOVING IGNITION SWITCH
Use a pin spanner to turn the outer switch cover to unscrew it. Remove the cover over the motion lever arm switch. Remove all screws from the control panel so it is loose. Push the ignition switch down under the panel, pull it out between the panel and fender, depress the tab on the connector, and remove the switch.
DISASSEMBLING IGNITION SWITCH
There are two tabs on the sides of the switch housing. Pull them outward while pushing up on the key cylinder (keyhole). It helps to put a small object in a vise and rest the key cylinder on it while you pull the tabs and push the switch down.
By comparing the ignition wire colors to the switch's terminals, you can figure out which terminal does what and how to check resistances to see if the switch is good. Removing oxidation from the copper contacts can reduce excess resistance.
WIRE COLOR CODES
B black
BR black/red
BW black/white
BY black/yellow
G green
GB green/black
L blue
LW blue/white
OR orange
ORL orange/black
P pink
R red
RB red/black
RG red/green
RL red/blue
RW red/white
RY red/yellow
V violet
W white
WB white/black
WG white/green
WL white/blue
Y yellow
YL yellow/blue
YR yellow/red
YW yellow/white
