New M6060 - Very little lift on 3 point hitch
ranger danger
Kubota M6060, MEB 802A tactically quiet generator
Jun 11, 2017
310
294
East of Placerville Ca
I love learning new stuff! I haven't had the need to go that high yet but, if I do, now I know how. Thanks for the edjamacashun!
treesmith
M6060
Jul 4, 2025
Alabama
I’d like to say THANK YOU to jwiatrek for post #40. My M6060 lift was ridiculously low. Why Kubota did something so blatantly stupid is beyond me. A tractor the size of an M6060, with the hitch arms nearly dragging the ground…unable to lift a bush hog high enough to clear obstacles…as I said blatantly stupid. A few minutes of adjustment got mine at least a bit higher. Between the arms being so low, and the attachment points on my bush hog and box blade being so high, it’s quite a predicament.
AOW162435
'25 LX2620 / '79 B7100 / '03 JD x595
Jun 16, 2023
160
90
Ellicott City, MD
So at its highest ... How much clearance do you have at the front of the cutter? I get about 5 inches at max ...
When trying to connect my auger this as high as it goes ... Cannot even get the auger under the gear box View attachment 72665
Have you moved the bolt that connects the boom to the auger frame?
Andreas
6,845
Andreas
Been a few years since he had the problem. Hopefully he has it figured out as he hasn’t been on OTT in a few years.
