Mower maintenance
Bearcatrp
Mar 28, 2023
1,114
738
Minnesota
Going to try to suck it out with a syringe. Hope it works. Don't want a big mess to clean up.
JimDeL
Aug 31, 2022
410
465
Austintown, Ohio
Should work okay. Big syringe with a large tip - maybe a short length of tubing on the tip.
5,506
2,214
i use a fluid evacuator for that too, among many, many other uses. refill with a hose on the end of the gear oil bottle's nozzle.
Mowbizz
Bx25d
Aug 19, 2021
573
332
Ha! Every time I’m involved with oil, there’s gonna be a puddle “somewhere”
My BX is mostly, fine but the newer zero (Z422KW-54) turn with that harder to reach oil drain plastic “nut” and hole in the frame that the oil is supposed to drain through usually has me swearing…🤣
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
175
183
The last time I changed my gear box oil I used the cap off of a paint can. I put it under it and let it drain.
When it gets near full, I cover the drain hole with my finger and dump the oil in a pan.
Hugo Habicht
G1900
Jun 24, 2024
1,139
1,648
Ireland
If i am reading this right, remove both plugs to drain, then put lower one back in and squirt oil in top hole until it starts coming out/the amount it calls for.
Probably does not really matter here but learning from car gear boxes and differentials I always open the fill plug first. Reason being is if you cannot open the fill plug you still have a driveable vehicle and can go to a work shop for help whereas drain plug opened and no oil in the gear box you would have a problem. With the mower you can still cut the grass and deal with the seized plug later.
5,506
2,214
precisely why I bought the mityvac. Well the first one. I broke it (ran over it) and bought another one which died. I was using them at work (kubota) and it became an essential tool for us techs. Bad part, they only hold about 2 gal, which is good and bad. Good, because it's a lot lighter than 12 gallons when it comes time to empty it. Bad because you have to empty it many times a day during lawn mower season when doing dealer work. So, I made my own rendition using a 12 gallon air tank that I had leftover from a project. I just used the venturi that normally hook the air hose up to, duplicated the plastic tank and how it all works but with a 12 gal tank instead of 2. Great. Oops forgot to figure out how to drain it "easily". Ended up having to flush/purge it, re-work the whole tank so that it has wheels and a handle, ran a second tube all the way to the bottom, a couple ball valves and bingo, pump out function. Roll it close to the drain barrel and hook the air hose up to it, shut a valve off, and watch it pump oil out. Takes about 1 minute to pump out 12 gal. Takes about 15-45 seconds to suck 2 quarts out of a lawn mower (gas engine) and never have to touch the stupid plastic drain plug. That in itself is worth it's weight in gold as a tech. Only one problem. Some customers don't see wrench marks on the drain plug and they'll question whether it was actually done or not...BTDT, still get that occasionally on polaris stuff.
Mowbizz
Bx25d
Aug 19, 2021
573
332
lol… I have one of those vaccuum pumps I used to use on an Argo 6 wheeler I owned…thanks for the reminder! 🤣
lmichael
Kubota G2160
Apr 23, 2021
785
390
Rockford IL area
Only thing I would like on my MightyVac is if it could also dispense. But, then it would mean you need to do a full clean out (rather than simply pour it out) to fill it with clean product and dispense it back into an engine or such.
Bearcatrp
Mar 28, 2023
1,114
738
Minnesota
Sucked it out today. Looked like it was new out of the bottle oil. Maybe metal particles I can’t see is why they recommend the oil change this soon. Will still change it every season for now on. That gear box can’t be cheap if replaced.
7,150
Different mower, but this is how mine gets stored as I said earlier.
I just drain out of the fill port. Refill it when it set it down to put under tractor.
(I leave a note on the box that says NO OIL as a reminder. Sometimes I get it ready a couple weeks before I refill the gearbox- bad things could happen with a feeble memory…..:oops:)
Going to need to mow next couple weeks. Blades sharpened and back on. Deck greased.
I drained the gearbox out today. Oil looked perfect, but I can tip the deck a little, and last few ounces look like they may have some moisture in it.
Crap in the Cool Whip container is from many years of use...... ;)
Probably changing each year is overkill. My lawn isn't that big.
Bearcatrp
Mar 28, 2023
1,114
738
Minnesota
Mine looked clean after 2 seasons cutting grass. May just change mine out every 2 years.
lmichael
Kubota G2160
Apr 23, 2021
785
390
Rockford IL area
Well to recap an issue I found myself having trying to grease that U Joint on the PTO shaft, I tried something different yesterday. I jacked the machine up after dropping the front mount and because of the angle I was able to get my Lock & Lube on it.
Hugo Habicht
G1900
Jun 24, 2024
1,139
1,648
Ireland
In my manual it says oil change every 150 hours. Gear box oil seal change every 2 years though 😲
As far as I know the SAE90 oil (used in my gearbox) is cracked mechanically by the gears over time, hence the oil change. Has nothing to do with wear and dirt that has to be removed.
lmichael
Kubota G2160
Apr 23, 2021
785
390
Rockford IL area
The gearbox on mine was rebuilt by a Kubota dealer in WI along with the spindles just before I bought the machine back in 2021. IIRC it had about 850 or so hours on it. I now have just a hair over 1000 hours on it. I changed the oil in the gearbox Monday. Used Lucas Synthetic 75W-90. Seems all the high end gear oils are 75W-90 rated. Which I guess is OK since this time of year and toward end of season I run the deck in some pretty cold conditions. But, I'm not touchin that seal unless it starts leaking. LOL. I've changed the oil in the gearbox 3 times since I've had it.
Still have yet to finish the full maint on the machine. Coolant flush/fill, air filter, hydro fluid screen clean and filter change. Still got a lot to do
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
688
195
Rising Sun, MD
I check the oil in my MMM gear box every 10 hours. A few years ago I lost a seal in the bottom of MMM gear box... and I am hard of hearing. Did not realize I had a problem until my neighbor told me something did not sound right. When I immediately looked into it .... the ONLY sound I could hear clearly was "Ka-Ching".
Hugo Habicht
G1900
Jun 24, 2024
1,139
1,648
Ireland
Interesting story, would not have thought this could happen, slow leak yes but not sudden loss. Thank you for sharing it ! To be honest, the tractor and deck is so noisy, I would not have heard that either. Possibly after the damage was done ...
Maybe time to reconsider ignoring the seal change maintenance. The seal ring has metal protection outside, could not find that anywhere. And I am not willing to pay the Kubota price for a standard part. Anybody an idea where those seal rings can be obtained?
lmichael
Kubota G2160
Apr 23, 2021
785
390
Rockford IL area
I have to clean debris from my deck a lot. So, I am constantly removing the 2 end covers and either blowing or washing out the debris on top, plus I'm always cognizant of looking for even slightest fluid leak from my equipment. I guess a catastrophic failure could happen while I'm out on the yard but, even then, having checked the fluid level prior to going out would not save the gearbox as then the only indication would be sound of gears ringing up $$$ signs
