Bx2350 tick.
New31127
Bx2350
Apr 24, 2025
20
North carolina
Cant seem to pin point it sound familiar to anyone? Have a video but dont know how to post it. The noise follows the speed of engine
New31127
Bx2350
Apr 24, 2025
20
North carolina
Sounds metallic to me but I layed on ground and stood above engine and couldn’t pin point where I thought it was coming from I adjusted valves and exhaust on 3 would slide back and forth the rest would not so idk if that is normal
9,732
Post the video on youtube then give us a link to see (hear) it.
New31127
Bx2350
Apr 24, 2025
20
North carolina
Is it the baffles in the muffler?
Story on tractor was it needed a new motor radiator was leaking etc and it wouldn’t run at all I got it and found what smelled like gas in the tank I changed all filters oil etc and seen no metal in oil filter put some fresh fuel and atf in tank and I think it was gas in the tank why it wouldn’t crank but I got it going seems fine other then the tick I’ve never heard a d902 before so idk if it was normal or not
9,732
Do an adjustment per the WSM on all the valves
9,732
Yea that doesn't look or sound right.
Let me see if I can find anything on that.
New31127
Bx2350
Apr 24, 2025
20
North carolina
If it has a rod knock I should be able to hear it just spinning motor over? Or no. Thought about pulling injection pump to check rollers and springs
New31127
Bx2350
Apr 24, 2025
20
North carolina
I did the old mechanics trick a searched around with a piece of wood and it’s coming from cyl3 but noise is much louder on the head and not the crankcase itself Also did the injector lines and the one for cyl 3 gave off a different noise then 1 and 2 Should I pull injector and move it to different cylinder and try that and if not check injector pump
2,532
I don’t think you would hear a rod knock under crank power. The starter is keeping it at a steady speed so nothing would be able to knock really.
2,532
Move the injector and see if the noise follows it.
2,532
Take valve cover off and adjust the torque of the rocker arm and then adjust (all?) the valve(s).
