Whos into home grown
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
Laid the rows in off in the big garden. Wife planted 19 tomatoes and 10 watermelon in the smaller patch.
Moose7060
Oct 14, 2023
827
2,243
bc
Plastic inflated "hoop houses" are the best.
If you use any type of wood frame, you are asking for short term rot.
I have had both.
My wood frame (Sitka spruce) house lasted less than 15 years, with constant attention to rot..
My 30+ year old (17x50) hoop house (galv. steel) is still standing, needing only 2nd time plastic replacement,,...30 . years later!
No wood. All aluminum and glass. Only issue is the odd bird flying in through the automatic windows and not knowing how to exit.
GrumpyFarmer
5,211
How wide are your hills?
Do you continue to hill as the plants grow?
If not what do you do with the low spot in between where your tires run?
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
Do you continue to hill as the sun plants grow?
No idea on the width. Once the green beans and peas pop up, I will hill with the discs a few times then just run the sweeps/feet until plants are too high and the stringer wire goes up to do so. Once that happens I walk behind till the tire paths if they get weedy. Probably not the most efficient way since the MX is so wide and it’s more work to open the ends of the garden to get tractor in.
I have the big EA garden bedder with the sweeps set as wide as they go and they just about set in the center of the tire.
GrumpyFarmer
5,211
Were a little behind you up here. The Big boys just now spending time in fields trying to beat the rain.
At our residence, we have transferred the first seedlings (cabbage, broccoli etc) from the basement grow lights out to the green house and we are planting the next batch for the basement (tomatoes and peppers etc).
Beyond that, today I picked up a trailer full of straw that we will plant into winter squash and cucumbers into (straw bale gardening) in addition to our traditional gardens. I’ll start the decomposition process this weekend on the new bales.
We are getting close but I have not yet hooked up the tiller or the garden bedder. We are getting close though. I hope to get some potatoes planted in May at our other place. (The worry I have is a late frost…still April and we are all budded out and fruit trees flowering…our bees are happy…but if we have a late frost that will put a damper on our peach trees)
GrumpyFarmer
5,211
We have beautiful sunny day today…low wind, sunny and 58. So we are recycling last years straw bales that we garden into, pile up (will use for mulch in garden after garden is planted) and the. Transferred the new straw bales into area where we will plant into it. After we condition the new bales (take about 2 weeks) then we will plant into the new bales.
GrumpyFarmer
5,211
We could use some rain, but they have started to pop…
GrumpyFarmer
5,211
Rain finally stopped here, so I made hay and then lasagna.
GrumpyFarmer
5,211
Sawburner
L2501, Gravely 526
Dec 18, 2022
109
344
NY
My Grand Daughter and I are introducing honey bees the there new home.
GrumpyFarmer
5,211
Sawburner
L2501, Gravely 526
Dec 18, 2022
109
344
NY
Looks great!
Just so you know, tucking pants into the boots like the person (pinkish/purple shirt) in picture is a great way to end up with a sting on bottom of foot when pull foot out of boot…I learned the hard way the first time I opened a hive.
Good to know, normally I tie a shoe lace around my ankles, we both will be doing that next time.
GrumpyFarmer
5,211
Hers a fun fact…my spousal unit is allergic to bees. She wanted bees and I thought it was horrible idea (she keeps an EpiPen with her) I said absolutely not unless get the immunotherapy…that took several years until the doc gave her the all clear. We got the bees…had them for several years and I am the only one that gets stung.
First time with our first hive I carried one back into the house inside my boot…ouch. Anytime we need to do something that involves gloves off, I am called to the mound and never fails I get stung…just part of it. At least spousal unit can safely bee around the apiary/bees.
I hope you and yours enjoy the apiary. Good luck.
GrumpyFarmer
5,211
Not much to share…asparagus is starting.
GrumpyFarmer
5,211
Looks like it’s just you and me @GrumpyFarmer . I guess @Fordtech86 is still playing with toy trucks!
Sure seems to be the case…if RC trucks had a rear pto and could run a front loader and a tiller, I might be joining the FordTech. 😉
we are still a bit behind you up here. We got into the 80s today which is a bit unusual but it should cool back off in a day or so. We have some seedlings started in our basement and some transplants from a week or so ago out in the greenhouse. We had a frost last week which is not uncommon for us and I really don’t like covering stuff up, so I follow the moon phases (it’s almost time to get serious) We’ve planted some greens in one garden and that is about it. If weather allows we may get a couple other patches planted this weekend (maybe try to get the beans in). Hope to blow the dust off the garden bedder and plant the next time we visit our place up north as well…all weather depending.
Some of the big boys / early birds rushed it this past week and you can pick their seed up with a front loader in the ditch today.
we still have another month or so until we pull garlic. I’ve forgotten what a fresh tomato tastes like.
2manybikes
19 L3560 HST with cab.
Aug 2, 2021
SW Va.
So, someone else gets it. I have three 'Horses". 84, 86 and 88 models. All with the Kohler 8 hp Magnum. Even if they were being used annually, they will still be in service when my grandchildren are too old to use them. I drove over 250 miles a few years ago to buy a "worn out" 8 hp Magnum engine that had been replaced by a Predator engine because it was smoking. Kind of like the Harley thing, "If I have to explain, you wouldn't understand." I totally understand what you said. Also, I did notice the engine on yours. My comments were not directed at that. Just the fact that the machine itself is a testament to what this country is capable of. So are the older Kohler engines.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
My $75 score a few weeks ago. Was told the tines wouldn’t turn and was disassembled 3 years ago. I checked everything over and reassembled, fresh gas and she fired up. Everything works as should.
I didn’t take it as a jab. I still have the original hh60 engine. Just needed something one pull dependable until I can refresh it. I do like the Honda though.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
210
339
Grayling, MI.
Our whites are out now too. Got some yard work to do today and didn't want to run over any Schroons. We don't eat them, but I give them to our neighbor. Good thing I checked as there was some large ones and one mutant. Schroons.jpg Schroons1.jpg
